Results 1 to 10 of 19
Thread: Faulty thermostat, does it damage the engine ?
    Regular Member deanos's Avatar
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Default Faulty thermostat, does it damage the engine ?
    Got a faulty thermostat, seems to have a mind of its own
    Does it do any damage to the engine at all ?
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Better not, mine has been dead for 4 years. It will lower MPG as the ECU thinks the Engine is having to warm up.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    It depends on if the thermostat is locked open or closed
    In most cases it will fail locked open, this is not an issue
    This results in overcooling the engine
    However, if the thermostat locks closed, then it is an issue
    This results in reduced cooling in the engine, and may eventually end in overheating and engine failure
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    The stat never goes above 85c , but like today it took over 20 miles before it moved but it only moved a little bit, later on it was 85c but then drooped down to the bottom again
    Its a 1.9 cdti if that makes a difference, thought diesels only use what fuel they need and dont waste it like a petrol , could be talking waffle but that's what i was told many years ago
    Regular Member collyb's Avatar
    Mar 2011
    ireland
    as gazza said,,,it may increase fuel consumption as an over cooling or stuck open thermostat will make the ecu work the engine slightly harder to get it up to operating temperature all the time,,,i drove a car once for a year with a termostat that never raised above cold,,and to be honest it never caused problems,,,they are handy to change tho mate,,and not that expensive either
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    It'll be jammed open. Common fault.
    Gazza4
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    Another one
    Had most of them now, wonder how many more to come
    Had a look and its quite a bbig lump to change, last time i changed one on an Escort it was just wedged in the pipe and 2 mins to change , things get too complicated nowadays
    Mar 2011
    ireland
    it took me an hour max to do my one mate,,,,,,,,theres a how to on this that u dont have to drain all the coolant from the system,,its a good guide
    Aug 2010
    Derbyshire
    Change it, simple enough if it's the 150.
    Mine was like you describe, it will be stuck open.
    Around £35 off ebay.
    Here http://cgi.ebay.co.uk/Vauxhall-Therm...item2eb4d7ada8
    Give em a ring first just to check you've got the correct one, next day delivery if ordered before 3pm
    There's also an 'How to' somewhere on the forum.
    Mick
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Its the 120 i have , seems to have a large silver round thing above it , looks a bit tricky to get to the screws.
    Thanks for the link
  1. Faulty Thermostat? & Loss of Power
    By Roswellian in forum Engine & Drivetrain
    Last Post: 3rd January 2013, 19:58
  2. Faulty thermostat on 2004 Vectra??
    By Meerkatonacid in forum Engine & Drivetrain
    Last Post: 13th June 2012, 19:27
  3. faulty thermostat/limp mode/spanner light
    By collyb in forum Engine & Drivetrain
    Last Post: 19th April 2011, 20:20
  4. Faulty thermostat fixed.
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2008, 02:32
  5. Engine flood damage!
    By John Arthurs in forum Engine & Drivetrain
    Last Post: 16th January 2007, 12:35
