Thread: Coolant Expansion Tank
    Regular Member Telboy's Avatar
    Apr 2006
    Leeds
    Default Coolant Expansion Tank
    Had a run out today and had a leak from my expansion tank out the pressure release at the back.Nothing major and all temps were fine all the time.One thing I have noticed is when I squeeze the pipes there is air coming out of the release release valve.Should this not be closed and if so do I need a new cap.Any other ideas what this could be as I can only see problem with cap being stuck open and letting coolant out rather than only letting it out when it should if engine overheats causing to much pressure
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Had a similar issue on mine. New expansion tank from the dealers is only £20. Get a new cap as well, they're about a fiver
    Easy to fit (half hour max), but get some coolant, as you'll lose some when you change the tank!
    Apr 2006
    Leeds
    I will get that sorted asap.Thanks for that I thought it would be something simple as had no issues upto today
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Best get a few hose clips too, as the original ones are a pain to refit!
    One for the bottom connection to the tank, and two smaller ones for the top two.
    hth
  1. Promotasport alloy coolant expansion tank
    By Kev_A in forum Quick Photo Album
    Last Post: 2nd September 2012, 17:24
  2. expansion tank
    By Swedge in forum Engine & Drivetrain
    Last Post: 1st August 2012, 18:21
  3. coolant bubbling from expansion tank 1.8LS 112k
    By TonyTangles in forum Vectra C / Signum Troubleshooting
    Last Post: 7th March 2011, 00:42
  4. Expansion tank cap!
    By MadOnVaux! in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2010, 17:51
  5. expansion tank
    By dilan in forum Vectra C / Signum Car Chat
    Last Post: 19th December 2009, 17:41
