Thread: Blowers not working
    Feb 2011
    North Wales
    Default Blowers not working
    The Blowers in the car stopped working the other week so did a quick search and found out i needed a new resistor and so brought one and fitted it, FIXED!!!! I thought brilliant, but then the other day they stopped again, working a number 4 but not the others, does anyone know if it is the resistor again or somthing else, just dont wont to go and buy another one.
    Thanks for any advice.
    DJM
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    it's classic resistor failure DJM,usually water that causes the failure have you washed the car since you fitted the resistor,if so check your drain pipes aren't blocked with leaves ect in the baulkhead just below the pollen filter
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by jonnybravo View Post
    Feb 2011
    North Wales
    Well that is what I thought, I cleared the drain hole the first time around when i put in a new resistor. But as I said before this worked fine but only for two weeks, then nothing.
    So today I went to maplin with the new resistor and asked them to check it and they said it was working fine, a current passing though it they said. so it cannont be the resistor?
    So I took the fan out (which was a misson) to check that the fan was running smoothly and it was ok but a bit stiff, put some wd 40 on it and a bit better.
    Put it all back together and still nothing!!!!!
    There is a clicking sound coming from the fuses next to the fan when i turn the swith from 1-3 so could it be the fuses and if so which one?
    It would be great to get this sorted for a cheap price, dont wont to take it to the stealers!!!
    Also not to sure whether I should just buy another one!!?
    Thanks for you posts
    Feb 2011
    North Wales
    Well I brought a new resistor and it works, will get back to you all to see how long it lasts!
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    You can repair the resistor with a thermal fuse from Maplin. Part number is RA23A. There's a How2 on here for it somewhere
    If the motor was stiff to turn, it will cause the resistor to run hot and burn out quicker. WD40 will help. Remove the pollen filter and give it another squirt again soon. Keeps it spinning freely
    Regular Member kicker's Avatar
    Oct 2007
    West Midlands
    I replaced mine two weeks ago and it also has gone again. The drain for the pollen filter was well clear. Booked in saturday at the VX dealer for them to check for parts warrnaty, although not fitted by them. Will take the glove box out for them as dont want them to charge me for that the gits!
    Oct 2007
    West Midlands
    ****** went again today!! Is this related?:::
    Nephew tried to open the passenger front window before letting me de-ice it first. As it was iced up, it struggled to open at first then it went with a little thud. That's when the heater switch only worked on speed 4 again.
    Or is it that they're just a crap resistor switch???
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Just to let you all know, the vx fix is also to drill a drain hole in the bottom of the housing.
    Sent from my Sony Ericsson Xperia using Tapatalk
    Dec 2011
    oxford
  1. Heaters/Blowers Only Working on No. 5
    By Madison5 in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2013, 00:47
  2. Blowers not working on any speed
    By noonaldinho in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2012, 10:45
  3. Blowers not working on number 1
    By tubby in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2012, 12:19
  4. Blowers not working on position 4.
    By Slammedorion in forum Electrical & ICE (including SatNav)
    Last Post: 25th September 2012, 18:01
  5. blowers only working on speed 4
    By cooki in forum Bodywork & Interior
    Last Post: 5th December 2009, 21:30
