Results 1 to 10 of 14
Thread: Rear Springs
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Default Rear Springs
    I've never changed rear springs before, just wondering if anyone knows how easy / hard they are to do? I've got a loud squeak when going over any sort of bump / speed ramp, etc, that can also be heard when you bounce the rear of the car (nearside only). I've got both springs ready, and will be tackling the job sometime this week.
    Can't seem to find a How 2 for this
    Car's a 52 reg 2.2 DTi SRi, if that helps
    Any advice / help / things to look out for would be great
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Blantyre
    Very easy mate
    Jack the car up and support it with axle stands
    Bottom of the hub, there is a bolt, torx one end and 17mm other , loosen this off but dont remove
    slide a trolley jack under the arm and jack it up to take the strain,
    loosen the bolt and remove completely
    lower the trolley jack and the arm will drop, allowing you to remove the spring,
    fitting vice versa to removal
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by spennny View Post
    Very easy mate
    Excellent. Do you know what size Torx I need?
    Regular Member Graham's Avatar
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Replaced mine a few months back. Read my thread. Same car.
    http://www.vectra-c.com/forum/showthread.php?t=131802
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by Graham View Post
    Excellent! Thanks Graham
    Regular Member Middo's Avatar
    Feb 2009
    Swindon
    v easy job mate,
    Regular Member Signum-Steve's Avatar
    Feb 2009
    Cramlington Northumberland, V6 Jaguar S-type Sport
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Year : 2003
    Quote Originally Posted by tony-1977 View Post
    Excellent. Do ypou know what soize Torx I need?
    I have a full set of torx so if you get stuck give me a shout and Ill pop down. I'm not to far away.
    Regular Member jimmyred's Avatar
    Dec 2010
    Southport
    this how2 about upper control arms has some relevant info on rear springs.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by jimmyred View Post
    That's excellent. Looks easy
  1. kyb rear springs
    By markmac21 in forum Suspension, Wheels & Brakes
    Last Post: 5th July 2012, 14:16
  2. Rear Springs - which ones?
    By Di frost in forum Suspension, Wheels & Brakes
    Last Post: 7th May 2012, 20:55
  3. Rear Springs
    By bobmcn in forum Suspension, Wheels & Brakes
    Last Post: 5th May 2012, 20:43
  4. For Sale: SRI rear springs £10
    By Jow20 in forum Parts for sale
    Last Post: 25th January 2012, 17:57
  5. Rear springs
    By bertbuckie1 in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2009, 17:26
