Thread: boot strip
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    Default boot strip
    i've removed the vectra badge from the chrome boot strip, to put an irmscher badge there, what's the best thing to use to get the marks off with ,cos you can still see the outline of the letters and i don;t want to scratch the chrome rubbing with anything to abrasive
    VOTING UKIP IN AVELEY
    6 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    a good polish .....maybe T cut if that dont work ...bug and tar remover ..lots of different things to try ....not all gaurenteed to work if lettering is old
    Regular Member shb1988's Avatar
    Oct 2010
    sittingbourne
    i used warm water and then just gently pick at it with your nails then tar remover after just to get rid of any left over glue hth
    Regular Member bigboynigs's Avatar
    Oct 2007
    ALDERSHOT
    same as others.............Autoglym bug and tar remover
    thought i also heard that Brasso did the job as well
    Aug 2009
    guys, thanks for the advice, but it's not the sticky residue i;m talking about , i've got that off , it's the word vectra is still visible on the chrome strip, it's as if it's left a shadow on it, i'm concerned that if i use t-cut or similar it will scratch and make a mess of the chrome....the badge i'm replacing it with is the word irmscher which , granted , will cover some of it,
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    autosol chrome cleaner fella
    Aug 2009
    thanks for that mate, i'll get me some autosol chrome cleaner then and give it a go,,,cheers
  1. Red boot strip please
    By RichM in forum Photoshop section
    Last Post: 5th January 2013, 12:29
  2. How 2 for boot strip
    By Carl83 in forum Styling
    Last Post: 31st December 2012, 00:20
