Thread: Swirl Removal
    Dec 2010
    Birmingham
    Default Swirl Removal
    Hi,
    I got my Signum a few months ago, and the previous owner must of liked the car wash. Its covered in swirl marks, and I was wondering how I could remove them. What hardware do I need and which polish do I get.
    All advice greatly appreciated.
    Aaron
    Liverpool
    meg's ultimate compound worked quite well on mine, also meg's swirlx too
    i have used most of my stuff by hand, but borrowed a DA a while back and got a hell of a lot out i could of never got out by hand. Worth borrowing one if u can
    Plus if its a dark colour, give poorboys blackhole a go
    Sodding Typical on Sea
    It can be done by hand as I did but takes hours of hard graft, if you get your hands on a DA (safer than a rotary for a beginner) then a product like Blackfire finishing polish I use is a 3000grit cutting polish so will cut and degrade to leave a mirror finish, but there are dozens of excellent cutting polishes to do the job.
    Good luck it is a very worthwhile process when finished.
    Dec 2010
    Birmingham
    Thanks for the replys, I should of said its black.
    Will give Ultimate Compound a go.
    May 2008
    Bordon
    Quote Originally Posted by Azz25 View Post
    Also consider Autoglym Super Resin Polish (AG SRP). Although it won't remove the swirls it will fill and mask them, topped with a coat of AG EGP you're car will have the appearance of being corrected. The product is also very easy to work by hand. Working a cutting compound by hand on a black car will almost certainly leave behind marring on the paint and you may make it look worse.
  1. Detailing and swirl removal
    By pipamish in forum Detailing and Car Care Discussion
    Last Post: 29th July 2011, 06:52
  2. Swirl flap removal?
    By iaind84 in forum Diesel Engine related
    Last Post: 24th January 2011, 14:42
  3. Swirl flaps, removal?
    By Derek Mc in forum Diesel Engine related
    Last Post: 17th November 2010, 13:55
  4. Swirl Mark Removal...
    By BigMan in forum Detailing and Car Care Discussion
    Last Post: 3rd November 2007, 12:39
  5. Swirl removal Video
    By Vectra Singh in forum Detailing and Car Care Discussion
    Last Post: 16th September 2007, 12:48
