Thread: 2.2 DTI Service
    Kent
    Default 2.2 DTI Service
    I've done a search but didnt find anything which would help, has anyone done a how 2 on servicing the 2.2DTI, would appreciate a guide on replacing fuel and oil filter if possible, may buy a haynes manual if not
    Regular Member paul.sessions's Avatar
    leighton buzzard
    undo sump plug drain oil,, then if you take off the engine cover the oil filter is at the front in a black plastic case (you will need a 38mm socket to undo this,, replace filter and the two 'o' rings. then refill with 5 litres then top up with another bottle will need roughly 5.5 litres back in there.
    leighton buzzard
    similar to this how 2 but my dti uses a torx drive in the sump plug and has a 38mm socket on the oil filter. . .
    http://www.vectra-c.com/forum/showthread.php?t=15115
    Kent
    great thanks, what about the fuel filter, just dont want to **** it up, bolt off and bolt on I can manage but never done oil and fuel filter change etc
    leighton buzzard
    the fuel filter is at the rear to the right of the coolant behind ecu plug ive not changed mine before, some of the horror stories put me off, althoughh i have drained the water from it.
    Kent
    doesnt sound good!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by paul.sessions View Post
    36mm for the filter housing bud
    leighton buzzard
    thats what i meant john
  1. Replies: 341
    Last Post: 20th April 2016, 06:29
  2. Service book - copy of service page (2.0 DTi)?
    By mvdg in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2011, 22:48
  3. Free MOT & Service reminder service
    By norfolk in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2010, 05:59
  4. 40k mile service and service light
    By a_j_mair in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2009, 14:41
  5. is there a way to reset service light yourself after a service?
    By EURO G in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2008, 00:14
vectra c 2.2dti service
vectra c 2.2 dti service
vectra 2.2 dti service
