Thread: front suspension knock
    Fife
    Default front suspension knock
    Hi guys my 56plate 1.8vvt sri navi has developed a knock in the front drivers side. I hear it when goin over speed bumps or any bits of cr@ppy road. Since iv got speed bumps in my street iv noticed I hear the knock when driving of the speed bump if you know what I mean??
    Just wondering if any1 has any idea what it could be? also how much a repair would cost as cash flow is extremely low at the minute
    Grantham
    Have something similar to my 07 CDTi - almost a mechanical 'ding cum clunck'! Checked with Vauxhall dealer mechanic as I thought it was the 'broken spring' syndrome but he tells me the front springs have a tendency to rotate and the noise is this small shift. Don't know if this is true but sounds plausible. Can be fixed if wanted by adding a shim but not necessary.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    As above or could be drop links or arb bushes both common faults on vectra,s and relatively cheap to put right
    and still loving it
    Fife
    thanks for the info guys. suspension problems effectively ended my last motor so hearing a knock was the last thing i wanted.
    a little warning 4 all if buyin an old focus for a run around. trailing arm bushes in the rear and other bushes in the front, design flaws in the focus mean its hard not 2 crack the suspension arm unless the right tooling is used. most garages wudnt even look at my car apart from the stealers who quoted £1500
  1. Diagnosing suspension knock
    By djlee in forum Suspension, Wheels & Brakes
    Last Post: 28th July 2012, 11:41
  2. Replies: 11
    Last Post: 27th June 2012, 21:54
  3. Self repairing suspension knock??
    By RLFH470 in forum Suspension, Wheels & Brakes
    Last Post: 29th March 2010, 13:43
  4. Sorry to ask about suspension knock again but...
    By Villers in forum Suspension, Wheels & Brakes
    Last Post: 28th January 2010, 23:53
  5. Front suspension rattle/knock
    By damian s in forum Suspension, Wheels & Brakes
    Last Post: 24th January 2010, 16:47
