Thread: Trolley jack question!
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Default Trolley jack question!
    Ive been given a new trolley jack, It was brought some time ago but not really used so when it did get used it was found to be faulty hence me getting it free, the problem is when pumped for the first inch its fine then wont go past that point, if slightly helped by hand after 2/3 inches its fine! & pumps & holds right to its limit, took hydraulics apart cleaned etc & new oil but still the same.
    Engine : 1.9 CDTi
    Does it have enough oil in it?
    Maybe the seal is gone.
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    If your using axle stands once lifted, then not really a problem.
    Not telling your granny how to suck eggs but never work on a car using a jack alone !
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    know what your saying mate! dont want a squished ed!, its just bugging me itsin brand new! condition & only one spot'ish then its fine, ive took the return spring off & it goes up fine where when the spring was one it kept pulling it back to the same point.
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    Quote Originally Posted by FIL 4822 View Post
    i do lol never use axel stands..............but yer sounds like oil or the seal
    north east
    Have you tried bleeding it ? loosen the screw pump the handle 15 times ( ish ) then tighten. Is it a clarke trolly jack ? they are known for it they will bleed themin the shop for free its that common.
  1. trolley jack
    By Swedge in forum The 'Off Topic' room
    Last Post: 13th December 2012, 19:23
  2. Which trolley jack?
    By peelmeister in forum The 'Off Topic' room
    Last Post: 6th March 2012, 11:10
  3. What trolley Jack?
    By Stevel in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2009, 15:40
  4. Off to buy trolley jack
    By shan in forum General Chat
    Last Post: 5th October 2008, 23:16
  5. Trolley Jack
    By Dave1.8 in forum Vectra C / Signum Car Chat
    Last Post: 7th October 2007, 18:36
