Thread: "whistling" fans
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    Default "whistling" fans
    It's only slight but enough to irritate me when the music is off, anyone know how to sort this?
    Regular Member Innes's Avatar
    Plymouth
    It sounds like the blower could do with a squirt of WD40. the easiest way to do that is open the bonnet. Remove the scuttle panel on the right and remove the pollen filter. Shine a torch inside and if the recirculating flap is open you should see the motor and vains. Hove it a shot of WD40.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    or take the glove compartment off and drill a small hole in the middle of the bottom of the fan housing and wd40 the bottom bearing..
    al.
  1. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  2. Any Katy Perry "fans"
    By Leemarksmith in forum The 'Off Topic' room
    Last Post: 2nd January 2011, 20:24
  3. worried!!!! have you ever used "corsa centre" or "supernovas"
    By vectra_c_wannabe in forum The 'Off Topic' room
    Last Post: 20th May 2009, 15:21
  4. "Goodbye" blue sky "Hello" grey !
    By FIL 4822 in forum General Chat
    Last Post: 8th November 2008, 15:43
  5. end of year bash 2008 "" will there be one ""
    By chrisgettings in forum General Chat
    Last Post: 3rd September 2008, 10:26
