Results 1 to 3 of 3
Thread: Newbie with a question
    Regular Member AlexGSi2000's Avatar
    May 2011
    Liverpool
    Talking Newbie with a question
    Hi,
    Purchased a 2005 Vectra 1.9 CDTi 150 two weeks ago.
    Iv had to search Google for a few things & its pointed me in the direction of Vectra-C.com - so guessed it would be a good idea to register.
    I purchased my Vectra with 120k on the clock, making sure the clutch and flywheel had been done - bodywork not perfect, few little issues here and there but I got it for £2500 with full service history - which I was quite pleased with.
    I purchased it as I had just written off my Ibiza Cupra R and need to get around for work .etc - I am still very much gutted about the Ibiza, as I had spent around £7k in the past two years and was nigh on 260bhp / 290lb/ft. But I was driving like a tool, so lessons must be learnt I guess.
    Since I have had the Vectra I carried out an oil and filter change combined with an engine flush (used fully synthetic 5-40w) - replaced a few little other bits, i.e-floor mats.etc
    Also replacing the thermostat next week, as its constantly reading a low temperature & only climbing when stuck in traffic.
    Heres my question - Whilst I was under the car I noticed gearbox oil slightly weeping out (about a drop every few days I would say) - but looking back through the MOT history on line, its had this oil leak for over a year.
    Im wanting to replace the gearbox oil and keep it topped up for peace of mind.
    Can anyone point me in the direction of the gearbox oil drain & fill points? Do they require any special key/socket? Also, how do I know when the gearbox oil level is full? (on my Ibiza I just filled until oil started coming out of the fill point)
    Many thanks!
    Alex.
    Sodding Typical on Sea
    Hi and welcome Alex. Indeed a decent sounding car, as for the oil leak do you have an idea as to where it is leaking? as that will be the first point to looking for a solution I would say. The second point it should be an F40 box and it is not the easiest to drain and refill from memory it has a plug under the weather shield on the n/s to refill it and the drain plus I think,,,,, think,,, is a large torx socket on the side like the one in this post.
    http://www.vectra-c.com/forum/showthread.php?t=114193
    May 2011
    Liverpool
    Many thanks for the link Derek.
    Haven't looked at it in depth, but initial inspection shows that its coming from where the gearbox bolts to the engine.
    As its only weeping, im just wanting to make sure its at the correct level - don't think it would be cost effective to get it repaired at its current mileage.
  1. newbie asking newbie question :-)
    By gavatron in forum Engine & Drivetrain
    Last Post: 6th February 2012, 10:39
  2. Newbie question
    By mikey2704 in forum General Motoring Chat
    Last Post: 23rd January 2012, 14:30
  3. Op-Com newbie question
    By Xerath in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd August 2010, 21:31
  4. Newbie question
    By RN37 VXL in forum Vectra C / Signum Car Chat
    Last Post: 16th October 2009, 21:51
  5. Newbie question about BC
    By TonyVectra in forum General Chat
    Last Post: 18th December 2008, 23:30
