Thread: Intermitent Oil Level Warning Light - 2.8 V6
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Default Intermitent Oil Level Warning Light - 2.8 V6
    Hi All,
    Just a quick question to see if anyone else has had a similar fault with their car.
    Every now and then, only happened around 3 times since I have owned the car in over 18 months but none the less, the Oil Level light comes on.
    Each time it has been whilst on the motorway on cruise control at around 90-100mph without adjusting it for a long time (and at night lol!).
    Oil Level warning light comes up on the dash and doesn't go. Everytime I pull over, check the oil and obviously it doesn't read well.
    Turn the engine off, leave it 5 minutes, check for leaks, nothing. Check oil level and its good again before starting up and carrying on the journey fine.
    The first time I pooed my pants and spent 25 euros on a litre of Shell Helix from a late night garage for nothing as I put in a drop and it was fine lol.
    My mechanical knowledge tells me that it is probably a sensor fault, however I wondered how common this is, and if anyone has resolved the fault?
    The only thing that concerns me is that the light stays on until its been switched off and turned back on and if checking the dipstick straight after stopping its not reading anything. Makes me wonder if the turbo or somewhere is creating a venturi and holding back the oil from returning to the sump... which wouldn't be good for the other engine parts
    Aug 2010
    Stoke on Trent
    I had a very similar thing in an old Vaux Cavalier... then one day the light came on, I stopped the car, turned off the engine, removed the key and the light stayed on!!!... it stayed that way (oil light on 24/7) for 3 days until after a short journey, I parked up (oil light still lit), went into my friends house and 15 minutes later the car was in flames...
    Glasgow
    Pretty common one this is and your right its a faulty sensor i do believe someone has mentioned on vxr online there is a software update possibly but dont quote me on that. But a new sensor and a software update check would solve the problem.
    Feb 2011
    bedfordshire
    Did anyone find the solution to this?
    On my 03 1.8 veccy the oil warning lights comes up on motorway journeys lasting over 20mins. After turning the car off for around 10 mins or so the light goes off. Also it never comes on when I drive to work which is about 10 miles up the dual carriage way.
    Bordon, Hampshire
    Quote Originally Posted by jimbojetset View Post
    Hahahahahaha! damn that made me chuckle... sorry for your misfortune but thats one heck of a good memory
    Bordon, Hampshire
    Quote Originally Posted by tony_b View Post
    I would put mine down to a sensor problem or possibly even a loose connection thats fiddling the reading But as said mine happens rarely... drove 150 miles the other day at 100-120mph average on the autobahn with nothing then back up at 85-90 on cruise control all the way and it was fine...
    There are 2 lights though... one is for pressure, one is for the level so check our handbook to match it up. I think the oil level has a wavy line underneath the oil can but don't quote me on that.
    If it is happening on EVERY journey over 20 minutes then its a bit more severe. But if its the oil LEVEL light and the level is fine when you check it then there cannot be a problem... but again it shouldn't take 10 minutes to switch off again...
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Quote Originally Posted by luke4487 View Post
    mine does it from time to time as well, it actually started again last week, so after work on Friday i jacked it up and reseated the connecter and its gone again.. Seems it may get nudged by road debris etc, on mine its at the top of the sump front sidewall...
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Mine came on 150miles into the journey and did not switch off until I got home, 700 miles later (left the engine running when filling up with diesel ). Oil level was fine...
    Only seems to come on on longer drives up an incline (Slovenia-Austria), never the other way (Austria-Slovenia)
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by Celes View Post
    Stay out of Austria then, and you'll be fine.
    Bordon, Hampshire
    Yeh and don't go down any Austrian basements... Mr Fritzle might be waiting to get you pregnant
  1. Oil Level warning light
    By Bren G in forum Electrical & ICE (including SatNav)
    Last Post: 9th September 2012, 21:55
  2. Fuel level warning light......
    By Nik in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2011, 00:44
  3. Oil Level Warning Light issue
    By Blagmeister in forum Engine & Drivetrain
    Last Post: 14th March 2010, 18:23
  4. Oil Level Warning Light
    By Gogs67 in forum Engine & Drivetrain
    Last Post: 16th November 2009, 20:25
  5. Oil Level Warning Light After Oil Change?
    By cmdzetec in forum Engine & Drivetrain
    Last Post: 6th May 2009, 19:56
vectra c oil light on long journey
signum v6 oil light on
