Results 1 to 10 of 28
Thread: Vectra lights
    Regular Member Philhammond2004's Avatar
    Feb 2011
    stafford
    Default Vectra lights
    Ive bought a HID kit for my Sri, had them professionally fitted, re-alignment they still dont seem to put the light down on the ground still.
    Does any1 know how I can Improve them? Is it because of the projector bulb? Never had this before on a car so dont know how they perform?
    Thanks for any replys/ Advice
    Sep 2010
    Can't understand the problem you're having. Most on here including me who has fitted HID's have noticed a huge improvement on the standard lighting.
    Regular Member Elahi_786's Avatar
    Oct 2010
    Bedford
    Mine seem to work best with the silver things at 12 o clock then the bulb at the bottom. Try adjusting your beam level
    Feb 2011
    stafford
    ive had my beams set 2 mot level on 3 so i can move them up, ive seen a big improvement. they was **** poor b4 but if i compare my lights 2my old car id say they was abit better on it. could it b power goin to my light or somethin? mayb there is a problem there?
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    which HID kit did you get ..and what was the output
    11 Post(s)
    Quote Originally Posted by Philhammond2004 View Post
    That's a bit silly. What if you have a full load on board? You won't be able to lower your lights down to stop dazzling oncoming motorists. You should have had them set on either 1 or 2 so that you still have some adjustment up or down.
    As to your other problem, have the bulbs been put in upsidedown?
    Feb 2011
    stafford
    got my HID kit from autolights.co.uk 6000k it what i had. n with regards to its abit silly with my lights. HiQ set it up not me n tbh i never have a full boot and if i do its normally in the day
    Bulb put in upsidedown? I didnt fit them, how wud i know if they r upsidedown?
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Think this is what he means Phil
    When the bulb is installed the metal rod should be at the top
    Attachment 41769
    Feb 2011
    stafford
    good diagram m8, ill have a look 2morrow when i have the time Cheers 4that
    Feb 2011
    stafford
    what r the effects of havin the bulbs upside down BTW?
  1. Vectra lights in France
    By rob1981 in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2012, 14:31
  2. Brighter Lights for side lights, Vectra SRI150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 23:50
  3. vectra fog lights
    By octoman in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2011, 01:07
  4. Vectra Sri Lights
    By Philhammond2004 in forum General Chat
    Last Post: 18th May 2011, 23:39
  5. vectra c lights
    By alan66 in forum Electrical & ICE (including SatNav)
    Last Post: 18th May 2009, 16:52
