Thread: Insignia Alloys on Vectra
    Regular Member bigstorer's Avatar
    Swansea
    Default Insignia Alloys on Vectra
    I fancy putting Insignia alloys on my SRi vectra but not sure what sizes would fit or even if the PCD etc would be the same. Can anyone help?
    Engine : 1.9 CDTi
    PCD is different.
    Vectra is 5 x 110
    Insignia (And new shape Astra) are 5 x 120
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    iirc the new astra has two different sizes depending on the engine. only the insignia is 5x120.
    Unless you can get some hub adaptors that won't throw the offset to pot then i'm affraid the insig ones won't fit
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    I hear theres some Polish Insignia VXR rip off rims floating around that have a pcd of 5x110. Wouldn't vouch for their quality though.
    Regular Member Hummelshøj's Avatar
    Aug 2009
    Denmark, Kolind
    Vehicle : Vectra C OPC Estate
    Trim : OPC / VXR
    Engine : Z28NET
    Exactly!!
    Vectra/Signum 5x110
    Insignia 5x120
    Astra J Petrol 5x105
    Astra J Diesel 5x115
    Not so easy to get different wheels anymore...
    Regular Member connery-sri's Avatar
    Basildon, Essex
    Someone on here has some insignia vxr reps on his vec c!!
    Sodding Typical on Sea
    Quote Originally Posted by connery-sri View Post
    :WHS: and they look the total mutt's as well
    Aug 2009
    Denmark, Kolind
    Trim : OPC / VXR
    Engine : Z28NET
    Yes but replica´s and original one´s are not the same..
    Original ones can not be fitted to other than the Insignia..
    Replica´s can many times to bought in other bolt cirkel´s
    Jan 2010
    York
    Quote Originally Posted by Hummelshøj View Post
    Really?
    5x110 - 5x120 PCD hub adaptor with correct hub centre bore to suit Vectra and perhaps less then up to 15mm would get the Insignia wheels on.
    I say 15mm wide max so as not to put the steering and suspension geometry too far out - should be within limits at 15mm IIRC.
    *EDIT*
    Not really measured up, but the Vectra hubs could even be re-drilled to the correct PCD - as long as the hub centre and Insignia wheel offset is right, then they'd fit!
    I do stand to be correncted though!
  1. insignia alloys on a vectra
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 22nd September 2012, 10:40
  2. insignia alloys on vectra
    By decks in forum Styling
    Last Post: 22nd September 2012, 01:49
  3. Replies: 10
    Last Post: 24th January 2012, 16:42
  4. insignia alloys
    By grumpano in forum Photoshop section
    Last Post: 29th March 2010, 13:32
insignia alloys
