Results 1 to 3 of 3
Thread: 2.0 dti won't start no compression
    Apr 2011
    Middlesbrough
    Default 2.0 dti won't start no compression
    Hi all
    My Vectra recently started showing the oil light on I checked the oil level and it was fine but when I was away and the wife was using it she put 3 litres of oil in and it started to smoke so her dad looked at it and drained the oil out and put the right amount of fresh in. He then drove it round the block and it was smoking and started to rev it's self up so he turned it off and it caried on running after a short while it cut out.
    Now it won't start and it turns over slightly faster than normal as if there is no compression on a few of the cylinders
    Any ideas
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    now then boro lad.. it sounds like its been running on due to being over filled.
    thats when the oil is forced up into the pistons and it burns and can make the car rev to over 10.000 rpm!..
    if you'v no compression now it dusnt look good pal.
    al.
    Apr 2011
    Middlesbrough
    Hi I assumed it was running of it's own oil as that's te only thing it could run off once the key is out but I thort it could only run of it's own oil when it has been vaporised by the turbo.
    If a seal has gone what seal is it likly to be and cost of repair
  1. No compression cylinder no4
    By r9 nml in forum Engine & Drivetrain
    Last Post: 23rd November 2012, 19:43
  2. No compression in cylinder no.1
    By boodoo warrior in forum Engine & Drivetrain
    Last Post: 23rd February 2012, 00:36
  3. Engine Compression
    By plasma in forum Vectra C / Signum Car Chat
    Last Post: 21st July 2010, 22:00
  4. compression z22se
    By delboy2028 in forum Engine & Drivetrain
    Last Post: 3rd January 2010, 20:56
