Results 1 to 10 of 11
Thread: Help - Drivers seatbelt issue
    Regular Member Vectra Forever's Avatar
    Apr 2011
    Somerset
    confused Help - Drivers seatbelt issue
    Hi all,
    I've got a minor problem with my drivers seatbelt on a 2002 2.2DTI. I've had a goot root through the forum and how 2's but not found anything.
    My seatbelt work as it should but is painfully slow to wind back in if not at all. It only just went through the MOT but now its nearly packed up. Does anyone know how to fix this, clean it up etc or even to replace the belt?
    Nev
    Engine : 1.9 CDTi
    This normally happens on higher mileage cars as the retracting spring looses its tension.
    Is your car high mileage?
    Apr 2011
    Somerset
    Hi lee,
    Yes it is a bit high. 105,700
    Engine : 1.9 CDTi
    Find a good one at the scrapyard and swap it over (Or buy new depending on what they cost)
    Apr 2011
    Somerset
    Hum.. Thought that may be the case.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    is 105k classed as high milage?
    al.
    Engine : 1.9 CDTi
    It is on a part that is used everytime the car is driven.
    I bet the rears or passenger one retracts better.
    Apr 2011
    Somerset
    Nothing wrong with those or the front pass.
    Regular Member rjw's Avatar
    Oct 2010
    cornwall
    Quote Originally Posted by Vectra Forever View Post
    is the spring the same on each? could you swap a rear one to the front?
    Apr 2011
    Somerset
    No idea. Given that it looks to be quite a complex / long job to change the belt, I think i'm going to get a 2nd hand one as new even on ebay is over £100. Looks like i'll be making a how 2 on this as well.
  1. Signum drivers window issue
    By Texx in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2012, 09:08
  2. Drivers seatbelt
    By Fitzy-2.0T in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2012, 01:40
vectra c drivers seatbelt retracts slowly site:www.vectra-c.com
