Results 1 to 10 of 24
Thread: vectra dti
    Jan 2010
    norfolk
    Default vectra dti
    hi goin to change oil on my 53 plate vectra 2.0 dti just wondered what the best grade to use is thanks , also going to change fuel filter to try to get mpg back as it is only doin around 39 to the gallon
    West
    if it's high mileage 10/40 will be best imo... & it's what i used on my preface dti
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    39's not that bad?.
    my 2.2 dti can drop to 39 if im hammering it around town but usually hovers around 45 ish when im very steady.
    exeter
    if you read the book its got to be 0/30 fully synfitic long life . because the sevice interverals are every 30k . but you wont like the price to change the oil will cost about £50 . but its worth it. mine does 50 mpg. if you use 5/30 long life it cost the same but you will need to change it every 10-15k . look at eurocar parts and type in your reg and it will tell you which oil for your car
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    5w30 is for 30k/2years intervals, 10w40 is for 20k/1year intervals. On our DTi I change the oil once a year at around 10-12k. Been on 5w30 GM until now, now I used 10w40 and the engine is much quieter
    Jan 2010
    norfolk
    thanks for replies ,its done 123500 miles , i thought it would do more to gallon , plus took top part of inlet manifold of and its full of soot would cleaning this help .
    West
    take the inlet manifold & elbow apart & clean it, then give it a good old italian boot up the rd!
    exeter
    Quote Originally Posted by Celes View Post
    i have just looked it up and he has the same engine as mine and mine uses 0/30 long life or 5/30 long life so the book says and garages and eurocars parts . the engine will be quieter the thicker oil you put in it but it does'nt do it much good
    West
    Quote Originally Posted by reeseandellie View Post
    it will do it no harm what so ever & will be better for it if the mileage is high, it won't weep past the seals like a thinner oil will.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Have to agree - on a higher mileage engine better to have a thicker oil to compensate for piston ring and bearing wear - fully synthetic is too thin - bit of advertising hype to get you to buy more expensive oils. Vauxhall recomend it because of their extended service periods - but who wants to leave it 2 years between services - I go for semi synthetic in my 04 1.9 cdti and change it every 6 months - no problems
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
