Thread: Engine management after airbox removal.
    Regular Member !tf's Avatar
    Apr 2011
    Chesterfield/Sheffield
    Angry Engine management after airbox removal.
    Removed my airbox and unplugged my air flow sensor. When i plug it back in and connected my airbox bag together the engine management light came on. Disconnected the battery for 45 mins and i still have the light on. I took the car for a drive and its driving as normal. No loss of power etc. Is this looking like a new air flow sensor? any tips on where i could have gone wrong.
    Thanks in advance.
    No need to disconnect the battery
    Just remove the ignition key and then wait 2 hours
    If you disconnect the MAF the engine goes into safe mode
    When you reconnect the MAF the fault code becomes stored (for 12 starts)
    After 2 hours the fault code becomes disabled
    Apr 2011
    Thanks for the reply mate. WIll i be ok to drive before i leave it for 2 hours?, as i am off to watch my team get relegated in a mo (Sheffield United)
    Northampton
    Engine : A20DTH
    Mileage : 88000
    The light comes on when you forget to plug the maf back in and start the engine. If you did this then the car will be fine to drive and the code will eventually go. If the light stays on all the time then you may well have damaged the MAF. Make sure you have plugged it in fully so that the clip activates
  1. engine management
    By crazyvectra2013 in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2013, 21:48
  2. Engine lumpy now Engine Management Light is on
    By Fitzy-2.0T in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2012, 16:51
  3. Replies: 3
    Last Post: 28th April 2009, 19:49
  4. Engine management light on after airbox mod
    By jsr645 in forum Engine & Drivetrain
    Last Post: 26th April 2009, 20:14
  5. just had engine management done
    By MAF 3.2 V6 GSi in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2007, 19:25
vectra c air box removal
engine management sensor vectra c 2.0t
airbox sensor engine management
vectra c air box
vectra eml coming on after air box
engine management cupra since airbox removal
remove air box cover now engine management light wont go off
where os airbox on vectra
how to take off air box vauxhall vectra c
vauxhall vectra air box removal
how to remive airbox vectra c
sri cdti took air box out now engine management light on
