Thread: rear door window removal
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Default rear door window removal
    how hard is it to remove the windows?
    al.
    Regular Member tolly's Avatar
    East Midlands
    Trim : SRI
    Engine : 2.2
    Year : 2002
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    sort of tolly..
    i friend of mine has broke he window and needs to replace it..
    al.
    Regular Member poves's Avatar
    lancashire
    Easy mate , just strip the door panel as per the instructions in thread.
    Then in the part of the mechanism that slides up and down in the door you need to retrieve the white round plastic plug . ( this may have fallen inside the door bottom . )
    Remove the corner section and undo the bolts and remove the bar/channel which the glass runs inside , this gives room to slide the new window in .
    If the replacement window has got the plastic clip already in the bottom , then happy days , it simply clicks into place ( make sure the mechanism is at the lowest point when it clicks in , and then refit the corner piece and runner bar.)
    If the window has not got the clip , you need to split the old one into two pieces with a screwdriver , then carefully put a side each on either side of the hole on the window and click it together , ( this must be done before the window goes in the door )
    Be sure to get the glass from the rubbers first , and hoover the bottom of the door out .
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    great
    cheers poves
    al.
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    TBH mate, i've done a few of these now and the easiest way i've found is to take out the seal that is inside the runners. It just seems to alleviate some of the pressure on the glass as you're trying to put it in. Where in West Yorks are you?
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    im in ponty but he's in leigh.
    i need to know for myself anyway cos im going to tint the rear windows and im sure they have to come out to be tinted, or at least the rubber seals taken off to get right into the corners
    al.
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Yeah man. When i tinted mine i took the glass out. I'm 99.9% certain that the tint film will get scratched it you try to put them back in with the rubbers in place.
    P.S. the white plastic cap is a nightmare.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    il be having a go soon cos the kids are cooking in the back
    al.
    lancashire
    Leigh in yorks , or manchester ?
    If he's in manchester I'm pretty sure I have a window , and will do the job for him at forum rates.
  1. Door card removal tips please... elec window not working!!
    By kev.whitehead in forum Bodywork & Interior
    Last Post: 10th October 2011, 22:47
  2. Removal/re-fit rear window vectra c?
    By Dean in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2010, 15:50
  3. Rear Window handle removal.
    By Brocks in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2007, 00:56
  4. Rear lil window removal?
    By 2ltrT in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2006, 18:05
vectra c rear door window removal
vectra c rear window removal yt
