Results 1 to 10 of 23
Thread: Fifth Gear
    Regular Member G.O'Rilla's Avatar
    Jul 2006
    On the road
    Default Fifth Gear
    Noted that apart from being a garbage programme, they also have a token "baby" presenter. As I write, they are now ruining a mercedes across england on chip fat and encouraging people to fiddle customs (OK it's not totally rubbish, then). Presumably the chips were used to fatten up the aforesaid presenter, but not VBH.
    Regular Member Silver V's Avatar
    Jul 2006
    mmmmmmmmmmmm
    mate goverment is a scam. chip fat can run in any diesel... even the newer ones, better off getting a decent filter though
    Jul 2006
    On the road
    Dr Diesel ran the original on peanut oil or something, but I am only putting EN590 in mine..................
    Regular Member Ian's Avatar
    York
    modern diesels, like the CDTi's need lubricants to help keep the pump healthy. i dont see why bio diesel cant be modified to include them? What the pollution rating of biodiesel?
    Feb 2006
    Guttedsville
    Don't know, but apparently you get fat kids chasing you!
    Jul 2006
    On the road
    reads fairly damning for biodiesel over 20% in diluition..
    quite a lot of information there that i had heard of but also quite a lot i didn't know.
    York
    Quote Originally Posted by Andrew's SRi
    awesome...mmmm chips!!
    I've just read up a little more on this. An Austrian research lab ran biodiesel 100% in common rail engines and after 100 hours of testing saw nothing wear more than if mineral diesel had been used, apart from the fuel pressure in the rail needed upping to get the same performance (tuning box anyone?). Apparently older engines with rubber seals are prone to to leaks. The only real issue for biodiesel is cold starts, but again an additive can be put in to drop the operable temp down to -22oC.
    According to the site, british manufacturers, such as Ford, will only warranty a 5% biodesiel 95%normal mix, but that is due to there being no British Standard covering biodesiel. A common mix is 20% bio, but to me that seems lots of hassle unless its premixed and comes straight from the pump like that.
    Oh that new presenter on fifth gear still sucks!
    Jul 2006
    On the road
    Loads of other stuff there as well - just go to the main site home page. If you are really bored the google biodiesel and try and sort out all the cowboys from the real stuff. We like the cowboys - they keep our labs ticking over nicely..... yeeeee hah!!
    Jul 2006
    On the road
    There is no British Standard because we follow European Standards, both for B100 and ordinary diesel. Any pump fuel MUST reach EN590, no matter how much Maccie D's waste there is in it. A bit tricky getting those burgers through the filters, though.
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2016, 16:15
  2. Gear lever,gear selector
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 09:43
  3. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
