Thread: loosing brake fluid
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    Default loosing brake fluid
    My warning light came on last week so checked the resovouir and it was low, so topped it up.
    last night the light came on again, and checked fluid and low and behold its dropped again.
    Ive searched all over the car but cant see any leaks, nothing on the drive. Am i missing something or does it just vanish into thin air?
    any ideas what to check on my z19dth guys?
    cheers
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    i would say the calipers leaking either on the front or rear, used to be the master cylinders on drum brakes were classics
    Engine : 1.9 CDTi
    Also its used for the clutch slave cylinder.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    If you cannot see a leak from the brakes then its the Clutch slave cylinder. Is there fuild coming from the clutch housing or any leeaks on the ground?
    West
    as above check round the bell housing for leaks, trouble is you may as well do the full lot (dmf & clutch) while you are at it as it's a big labour job... about £600 all in.
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    after getting the car up today on the ramps i did find some oil residue on the rear n/s seems to be down the side of the petrol tank, its defo not fuel. any ideas guys?
    cheers
    Engine : 1.9 CDTi
    Maybe the pipe is corroded or there is a join up there.
  1. brake fluid
    By vectraross in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2012, 01:09
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. Dot 5.1 and Dot 4 Brake Fluid
    By smitd004 in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2011, 12:36
  4. brake fluid
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2011, 12:41
  5. Brake Fluid
    By parapaul in forum Suspension, Wheels & Brakes
    Last Post: 23rd August 2008, 12:27
