Results 1 to 10 of 15
Thread: finally cracked it
    Regular Member collyb's Avatar
    Mar 2011
    ireland
    Default finally cracked it
    well guys,,,my limp mode spanner light misery seems to have come to an end,,,after a new manifold,a cleaned egr valve a cleaned boost pressure sensor,,a cleaned and soldered throttle body,new injector seals,, new glow plugs,,a new thermostat and a full service,,,,,,,,,, 400 miles after all this and the car is running like a dream,,,,... i must say,,these are complicated cars(vectra c),,but when they are running right,,they are a joy to drive
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Good m8, glad it's sorted. Now go and enjoy some CDTI 150 power.
    Here's one for you, what would cause the rev counter to sit 1,000rpm when you press the clutch occasionally? Sometimes it will drop down to idle speed (850rpm) but slowly creep up to 1,000rpm? Very strange. That's what my car does.
    Gazza4
    Mar 2011
    ireland
    do u think it cud be cruise control related mate,,,(does ure elite model have cruise control) i think i read before about a spring in the clutch pedal that sticks sumtimes while in cruise control....i cud b wrong ho mate
    Mar 2011
    ireland
    i think a faulty crank sensor can cause this too mate
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by collyb View Post
    Yeah it has it m8 but the spring is the updated one.
    I fear Injectors, was fearing turbo vanes were jamming but I am guessing the injector(s) may not be behaving.
    Gazza4
    Mar 2011
    ireland
    just read this from another foum gaz,,,i think it could be related to throttle body plate u removed ??????????? -----I had a similar problem -overrevving engine without depressing accelerator- in my Siena 1.6. I had to have the throttle body changed to fix it. I suspect it must have been a malfunctioning sensor -perhaps the one sensing the throttle position (is this the actuator mentioned by vijayrv ?)- and the ECU must have thought the accelerator pedal was depressed when it was not.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Regarding the crank sensor - that crossed my mind. And is plausible, the sensor could be telling the ECU the engine is running lower rps hence fueling is altered.
    The plate is always opened m8 on deisels. Removing it won't change it and it was doing that before. But I think it's time I soldered the dam thing.
    Soldering Iron for me tomorrow.
    That's been a big help bud and given me a few ides to try out. Even though the plate has been removed, I should remembered one fundamental thing - the sensor fault is still there, it's still giving the ECU false data. Cheers m8,
    Gazza4
    Mar 2011
    ireland
    no problem mate,,,,id say u will get her sorted,,,,fingers crossed
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Yeah, never thought of the throttle fault the way you did, certainly pays to see others thoughts on a subject. Well cheap fixes first.
    Gazza4
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    I had a similar problem with my 3.0CDTi and after I replaced the injectors the fault seems to have disappeared. Now...I'm not sure it is related as this happened very very rarely anyway
  1. Another cracked vxr wheel
    By 0114NIGEL0114 in forum Handling & Braking
    Last Post: 31st August 2012, 23:43
  2. 2.2 head cracked
    By srikev in forum Engine & Drivetrain
    Last Post: 10th December 2011, 20:54
  3. Cracked Snowflake
    By Aidi in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2011, 11:16
  4. Cracked Windscreen
    By 2.2direct-sri in forum Vectra C / Signum Car Chat
    Last Post: 10th September 2007, 23:51
  5. Cracked Window
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2006, 22:00
