Results 1 to 10 of 24
Thread: Want to fit an outside tap....is it easy?
    Regular Member wingz123's Avatar
    Mar 2011
    M4 Junc 12
    rolleyes Want to fit an outside tap....is it easy?
    I need to fit an outside tap.....anyone know how to do this at all? maybe I'm weird but I find cleaning my car very therapeutic and wnat to start cleaning it regularly.....at the moment I'm having to take it down the local hand car wash to get it cleaned and want to do it myself!
    I don't know how to do it myself...
    My recommendation is to install a stop-**** between the supply pipe and outlet to the wall
    That way if the pipe freezes and splits it can be turned off, without affecting the main supply pipe providing that water
    Use a plastic pipe suitable for external grade work between the external tap and internal pipe
    Completely fill the gap in the wall
    There are loads of different types of fittings and materials, so make sure the ones you select are up to the job
    Mar 2011
    M4 Junc 12
    ah man I'm not good with things like this!
    Quite a bit more reading i think is needed on my part....
    Jul 2010
    Warrington / Liverpool
    Very easy job mate, like your man above said you want to be able to isolate it independantly but then it is as simple as buying your self a Tpiece and tapping into your cold water pipe...
    Usually do it under your kitchen sink and just go straight through the wall but depends where you want the tap obviously lol... Just try and drill diagonally down slightly through the wall and make sure your fill the whole well around your pipe.
    Mar 2011
    M4 Junc 12
    I've got cladding on the outside of the house....is this a problem?
    Jul 2010
    Shouldnt think so its propbably only decorative... drill through the cladding first so its nice and tidy then drill from the outside in (and diagonally up) so you dont damage it, is it just a breezeblock wall behind?
    Mar 2011
    M4 Junc 12
    i think so mate - I've just got all of these visions of water spraying out ( i know you turn the water off first).......
    Jul 2010
    Hahaha, whats the worst that can happen... She'll just have a bit more to clean up after you
    Joking of course!!!!
    Mar 2011
    M4 Junc 12
    hahahah......
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    The other reason for having an internal cut off is so the local louts can't amuse themselves by turning it on late at night - handy thing to have though, an outside tap, and not that hard to do.
  1. Easy
    By Big Knox in forum World Cup chat!
    Last Post: 19th June 2010, 19:33
  2. Tax The Easy Way
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2008, 20:15
  3. IT help: how easy is it to....
    By Harry in forum The 'Off Topic' room
    Last Post: 3rd March 2008, 20:24
  4. How easy is it to fit these....
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2008, 20:44
  5. how easy??
    By lee_eardley in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2007, 21:08
