Thread: Timing chain on a corsa
    Regular Member johnnyboy1985's Avatar
    Aug 2010
    Letchworth Hertfordshire
    Default Timing chain on a corsa
    My girlfriends 51 plate corsa sounds like sewing machine and i think it maybe the timing chain as its a metal rattle noise from the engine..how much would she be looking at getting this changed? could it be done on the drive? the cars done 122k
    Regular Member Mopar Man's Avatar
    herts
    If its a 1 litre three cylinder, through it away.
    1.2 upwards ok. You have free floating cams and sencer, so you cant do it without the correct tools. The engine mounting, water pump, chain cover and more all have to come off.
    This is a very common problem with corsers.
    Aug 2010
    Hello alan how much does a garage normaly charge for this? is it fine to drive?
    north east
    Have a pop over to corsa-c.co.uk , they are well known for issues with the timing chain, its normaly just the tensioner but its a pity to pay all that labour and not replace the chain.
    Not really a diy job its £80 ish for the locking tools, £100 for the chain kit which you also need to add sump gasket, wather pump gasket and oil .. may as well change he oil filter while your dropping the sump.
    Local indys normaly £240 ish all in you may want to get the water pump changed while its all apart.
    herts
    You may as well just let her drive the Vectra instead
  1. Timing chain
    By signumboy in forum Engine & Drivetrain
    Last Post: 11th August 2011, 18:19
  2. corsa 1.2 timing chain
    By marktaylor in forum The 'Off Topic' room
    Last Post: 12th July 2011, 09:18
  3. timing chain
    By barneyp06 in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2010, 11:04
  4. corsa-c timing chain
    By the-wizard in forum General Chat
    Last Post: 12th November 2009, 08:19
  5. timing chain
    By gsp1 in forum Engine & Drivetrain
    Last Post: 25th May 2009, 23:13
