Thread: maybe dpf problem
    Apr 2009
    Leeds
    Default maybe dpf problem
    hi all
    i,ve got a 2005 cdti 150 vectra
    been having a few problems it starts fine but will not rev freely it take about 10-15 secs 2 touch 4k
    no fault codes at all
    swirl flaps disconnected since i got car bout 2 years
    i was advised it was a blocked (choked up) inlet manifold so i have removed it today (**** of a job lol) it is coated a bit with soot but dont look to bad
    i ave now been advised it cud be the diesel partical filter
    the timing belt also looked like it was starting to preish its only 55k n 3 years old is this normal i thought change interval was 100k
    so any idea,s
    cheers in advance guys
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    could well be but it would go limp mode id sayand you should of done cam belt as you had the car in bits take dpf off and jet wash it or replace it
    id take it off start car if revs like it shoud its dpf easest way id say didnt you try this?
    Apr 2009
    Leeds
    i can do cambelt mate cars is still in bit not put manifold back on yet
    is it ok 2 jet wash them lol (never heard that before)
    Sep 2010
    in a box
    Quote Originally Posted by marc7 View Post
    gd gd well some bloke did it on here so yer is say ok iv gutted mine and taken off the ecu
    Administrator plasma's Avatar
    On the Forum
    410 Post(s)
    Engine : 150
    Mileage : 74000
    normally its EGR causing it to take time for revs to rise.... not normally manifold though, but to prove its not the dpf disconnect the turbo downpipe and see if that cures it.
    Sep 2010
    in a box
    Quote Originally Posted by plasma View Post
    would it not be easyer at the dpf as them turbo bolts are a *****
    ok how is ***** a swear word its the name of a female dog lol
    On the Forum
    410 Post(s)
    Engine : 150
    Mileage : 74000
    was basically agreeing with ya never removed either so wouldnt know tbh.
    Apr 2009
    Leeds
    i run car with egr removed but was still same
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Do you have Hatchback or Saloon?
    Its only the Estate and Signum that have DPF's
    Your problem could well be the 3rd injector wiring whcih needs to be replaced, known fault and a kit is available from VX
    Regular Member badback's Avatar
    Runcorn
    Quote Originally Posted by merikiito View Post
    ..and auto hatchbacks have dpf.
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
