Thread: How do I change the carpet?
    Engine : 1.9 CDTi
    Default How do I change the carpet?
    How easy is it to change the carpet on a signum?
    I bought a travel assistant from a friend (As he never uses it) thinking I could get the the fitting kit but its now not available.
    My mate has said I can have his fitting kit but I would need to swap carpets too so he isnt left with a hole.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I would think you're looking at what amounts to a full interior strip out (seats, footwell trim, lower B pillar trim, centre consoles out), less roof lining, dash and door cards.
    Quite a job.
    BUT....
    On the positive side, it would give both vehicles the opportunity for a 100% interior clean out, tidy up and general spring clean.
    Engine : 1.9 CDTi
    How does the centre console come out as it looks like I will be starting on mine today
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I did this on my brothers Vectra, it's a seats out and centre console
    Irmscher Insignia CDTI 130
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Centre Console (according to Haynes)
    Front seats out.
    Pop Trim strip off over glovebox.
    Lift out ashtray and remove trim around socket. Unplug socket.
    Unclip gearstick gaiter.
    Undo 2 screws - 1 under lower middle of each fascia vent.
    Undo 1 screw - rear left of centre console (front left of gearstick area)
    Remove caps either side of console - would be by passenger's right hip and driver's left hip. Undo revealed nut & screw.
    Lift console and slide to rear. Remove from car.
    Rear console:
    Prise out and power socket panel. Disconnect & remove.
    Undo 2 screws securing console to floor.
    Undo 4 bolts (2 either side) above just removed screws. Remove armrest and vent housing.
    Pop out cupholder/tray by handbrake.
    Undo screw now revealed at front.
    Slide console to rear. Lift over handbrake and remove.
    On completion, go buy Haynes manual so I have to type far less !
    Engine : 1.9 CDTi
    Thats great thanks
    Engine : 1.9 CDTi
    Carpet and seats (Apart from the drivers) are now out.
    Only pain is I have to go round a mates house to swap carpets which will put the airbag light on.
    Will just have to reset it with my code reader when I get back from swapping carpets.
    Thanks again for the pointers.
  1. removing front seats/carpet change
    By vectraross in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2012, 21:59
  2. What are these on the carpet?
    By weidass in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2012, 12:15
  3. carpet
    By rave5 in forum General Chat
    Last Post: 2nd January 2010, 00:39
  4. car carpet
    By neverlandandy in forum General Chat
    Last Post: 25th March 2009, 13:41
  5. Carpet mat set Vec C
    By blue estate in forum Parts for sale
    Last Post: 19th March 2008, 22:31
remove front carpet vauxhall vectra
how remove vaxhall vectra carpet
