Thread: Spanner warning light stays on
    Apr 2011
    Reading
    Question Spanner warning light stays on
    On starting the Vectra ( 1800, LS, Petrol, 12/2001 ) all lights go off as normal.
    After 5-10 minutes the SPANNER light comes on and stays on.
    Only thing I have done is replace the exhaust pipe.
    Car also seems to be getting thirsty.
    Any tips ?
    Look in the how2 section for the pedal trick - a free way to read out fault codes.
    Failing that, you'll need to pay for a diagnostic check as guesswork was never a reliable method of fault finding.
    Apr 2011
    Reading
    Did the Brake/Throttle routine and got the following codes ...
    1555 and 0700 or 0701
    Engine : 1.9 CDTi
    P1555 "Throttle Position sensor/Mass Air Flow sensor - Implausible Signal"
    P0700 "error in transmission control module memory"
    P0701 "Transmission Control System Range/Performance"
    So you have some sort of Auto gearbox problem and possibly a faulty ait flow meter.
    Start with giving the AFM a clean.
    Apr 2011
    Reading
    It's a Manual gearbox
    Engine : 1.9 CDTi
    Then the codes are wrong.
    If your ever near Portsmouth give me a shout and I will read the codes for you.
  1. Spanner light now stays on, them EML light!(1.9 150)
    By adamf in forum Engine & Drivetrain
    Last Post: 17th March 2012, 12:31
  2. Petrol Warning Light Stays On
    By seanp in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2012, 14:03
  3. Spanner Warning Light Stays On
    By Englishman in forum Troubleshooting
    Last Post: 8th May 2011, 01:00
  4. Car and spanner light now stays on?
    By danny1992 in forum Engine & Drivetrain
    Last Post: 7th December 2010, 14:04
  5. car and spanner warning light
    By paul515 in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2009, 01:49
