Thread: gearbox?
    Sep 2010
    doncaster
    Default gearbox?
    Hi all,
    After coming down the motorway and and changing to 5th gear i noticed a really loud wining coming from 5th gear, also when i got home, clutch struggles in reverse and there is an electric noise in 1st and 2nd, also it rattles when i release the clutch, going quiet when i press it back in, any ideas? clutch? gearbox? or dmf? also i noticed when pushed in first gear the wine in 5th also comes and goes in 1st too..
    Jezz
    lincolnshire
    from that description bud it could be all three !?
    Sep 2010
    doncaster
    ok, i took it to the dealer and they said they want 285 pounds to look further into it by taking the gearbox off and checking if its the clutch or box. Gearbox is covered under warrenty..Clutch isnt, Also does the DMF come with a clutch kit?
    Thanks..
    Jezz
    May 2011
    Ilkley
    Did you find out what the problem was Jezz as I think I got same problem, sounds like what I can only describe as an electric jet powered tram on uneven rickety rails in all gears. Started off with a judder, progressed in a day to a whining with judder, now I have very slight judder with horrible sounds coming primarily from underneath passenger side ( noticed by opening both windows at speed ). The faster I go the least noise I get until I begin to slow down. I'm thinking either gearbox/ clutch / DMF or even driveshaft. Clueless really.
    Sep 2010
    doncaster
    Well after 22days at the nissan dealer (Evans Halshaw Doncaster) i finally got my car back from them after complaining that many times to them. They put a new clutch, Flywheel and recon the gearbox in it, and it drives better than it ever has, Clutch is quite low as it used to be very high..Just got a cambelt to do now as car has 106000 on it 55 plate 1.9cdti estate..
    Jezz
    Regular Member AlexGSi2000's Avatar
    May 2011
    Liverpool
    Could have possibly been the gearbox oil too low?
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Gearbox and Gearbox Oil question
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2011, 17:01
