Results 1 to 10 of 17
Thread: Brake pad warning sensor?
    Woodbridge
    Default Brake pad warning sensor?
    Does a 05 1.9CDTi SRi have pad warning sensor's?
    I only ask as the wife's vec went in for a service and an advisory was the near side sensor had been ripped off.
    I was un aware of any brake pad sensor on this car.
    Apr 2011
    midlands
    not 100% sure but i have a 54 plate and i know mine has one
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    prefacelifts have them, facelifts dont as I found out the other day....
    Think the rule is something to do with if you have a black or grey connector plug which the abs plugs into underneath the wheel arch...
    Woodbridge
    Are the front's and rears connected? Or do they only have them on the front?
    VX said the rear pad wear is 90%, but no warning light has come up. Vauxhall gave me a real good quote of £110 for rear pads fitted... So good of them.
    West
    the sensor is only on the front nearside & as said facelift don't have one
    Woodbridge
    Ah ok, I might have to look into it. Cheers guys.
    Quote Originally Posted by Ginge7289 View Post
    Yes, as above fitted to the nearside front only
    Why, what is wrong?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    If the sensor has been "ripped off" then you'd have a pad warning light on. Sounds like your dealer is "at it"
    Sorry, missed that bit
    It's not that difficult to refit and during a service with the wheels off is even easier
    However, the sensor will not report brake pads worn if simply removed, the contacts need to be worn through and no longer in contact
    Sounds like a previous owner might have got fed up replacing them, ripped it out, then shorted it, and tied it up out of the way
    Woodbridge
    Well, TBH do I really need the sensor? I have managed for 11 Years of driving without one and have always managed to work out when the pads new changing. I may take the wheel off, just for an excuse to play with the car for an hour or so.
  1. Brake Pad warning sensor
    By tutfut01 in forum Detailing and Car Care Discussion
    Last Post: 15th September 2010, 14:47
  2. front brake pad warning sensor
    By darkmandonny in forum Suspension, Wheels & Brakes
    Last Post: 5th December 2009, 13:03
  3. brake pad warning sensor/wire???
    By big rich in forum Suspension, Wheels & Brakes
    Last Post: 23rd January 2009, 16:41
  4. Replace brake warning light sensor - help
    Last Post: 12th January 2009, 18:28
  5. Brake Pad Warning Light and Sensor
    By andy13 in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2008, 19:18
brake pad sensor vauxhall vectra c 1.9 cdti
