Results 1 to 10 of 24
Thread: Struggle to start when cold and cloud of smoke
    Apr 2011
    Berkshire
    Default Struggle to start when cold and cloud of smoke
    On my 2.2 dti when the engine is cold it struggles to start first time and when does a huge cloud of White smoke comes out the exhaust,
    I changed the glow plugs yesterday, any idea what else could cause this, as it quite embarrassing starting car and filling the area in a thick cloud of smoke
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    The white smoke could be coolant. Does it use any coolant?
    After changing the glow plugs yesterday, did it start any better today?
    Apr 2011
    Berkshire
    No coolant fine, and no it didn't start any better, I thought changing the plugs would have sorted it as they were knackered and would bring engine management on, when started
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    How long does the glow plug light stay on for before you start it? Having said that, in the winter, my 2.2 DTi SRi will start in less than 3 seconds without using the glow plugs.
    Also, when was the air filter and fuel filter last changed? And check all the vacuum hoses and leak-off pipes for splitting
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    Have you changed the bleed of pipes and the diesel filter ?
    Dose it start ok when engine is warmed after a drive ?
    West
    leak off pipes & injector seals are common causes of poor starting, the glow plugs will not make a blind bit of difference when the outside temp is above 5*c... once the above have been ruled out you should then start looking at the starter motor, battery & then compression.
    Apr 2011
    Berkshire
    I have changed fuel filter, I'm going to order some fuel leak off pipes today, will see if that makes a difference,
    The car starts fine when it is up to temperature
    Apr 2011
    Berkshire
    It has had a full service over the last week along with brand new vacuum pipes so no splits
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    White smoke is unburnt diesel.
    How old is the battery?
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Just as a test, park it pointing down hill. See if it starts better. If it does, it's probably leak off pipes or injector seals.
  1. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  2. Blue smoke from cold start
    By Ebbey in forum Vectra C / Signum Troubleshooting
    Last Post: 5th May 2012, 16:53
  3. Gray smoke cold start
    By antchris5 in forum Vectra C / Signum Car Chat
    Last Post: 7th October 2009, 02:11
  4. cloud of smoke on start up !
    By G4VNM in forum Engine & Drivetrain
    Last Post: 5th July 2008, 01:14
  5. White Smoke - Cold start
    By DG01 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 21:12
vectra c huge smoke winter
