Thread: Loosing power.
    Apr 2011
    South Wales
    Default Loosing power.
    Hi,
    I have a 1.9CDTi 05 plate saloon, over the last week I have been having an intermittent problem with the power dying whilst driving.
    When driving along the car seems to just loose power when in sixth gear and when I change down it does not pick up straight away but seems to keep dying.
    It feels like the car is running but the turbo is not engaging as it should, as you can then feel the turbo kick in. I have also had a problem where the car is very sluggish pulling off from a standing start, I put this down to the diesel I put in at a supermarket garage as I could not get Esso diesel when I needed it.
    These problems seem to have arisen since this diesel has been put in, could this be the problem or could it be something else?
    Regular Member GTS's Avatar
    Oct 2010
    Poland
    Has similar sympthoms with my 120 cdti. Check your airflow meter, maybe this helps.
    Vehicle : Insignia sport tourer 2.0 CDTi
    Trim : /Elite
    Mileage : 34900
    As above with the airflow meter could also be your boost sensor needing a clean
    and still loving it
    Apr 2011
    South Wales
    Thanks for the responses.
    What do I need to do to carry out your suggestions?
    Where is the airflow meter, how do I check it?
    How do I clean the boost sensor, would something like Forte do this or does the sensor need to be removed to clean it?
    Trim : /Elite
    Mileage : 34900
    Your airflow meter is inbetween the airbox and your turbo , your boost sensor can be found by lifting off your engine cover and at the rear of the engine on the right just above your egr valve
    pic of boost sensor enclosed
    and still loving it
    Oct 2010
    Poland
    If you dont wanna go to stealers just find any diagnost or mechanic who can check it with software.
    Regular Member GrantAbs7's Avatar
    belfast
    This is the how2 for cleaning the boost sensor
    http://www.vectra-c.com/forum/showthread.php?t=88845
    Apr 2011
    South Wales
    Thanks all for your help.
    With reference to the airflow meter, what do I need to do to it? Clean it or replace it?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    As you say it occured with the supermarket diesel, why not get the fuel filter changed and use diferent diesel?
    MAF sensors are delicate and imho I doubt that's the cause on the basis of what you have said regarding the diesel you have put in.
    Gazza4
    Regular Member wingz123's Avatar
    Mar 2011
    M4 Junc 12
    Bob you are the king at giving diagrams!!! Top man
  1. 150 facelift loosing power sometimes
    By lutonmatt in forum Engine & Drivetrain
    Last Post: 16th April 2012, 20:06
  2. keep loosing power steering
    By DTI Dave in forum Suspension, Wheels & Brakes
    Last Post: 4th January 2012, 16:56
  3. engine loosing power
    By dti owner in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2011, 05:38
  4. Help - loosing power
    By ps2user in forum Vectra C / Signum Car Chat
    Last Post: 9th September 2010, 14:04
  5. loosing power
    By john barnes in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2009, 20:52
