Results 1 to 2 of 2
Thread: Replacement of Rear Drop Links
    Regular Member Jekyll & Hyde's Avatar
    Walderslade Woods,Kent.
    Default Replacement of Rear Drop Links
    Hi
    I have just replaced my off side rear upper control arm, & was going to replace my drop links, but didn't. I wasn't quite sure how to do it.
    Do you take tension off of the suspension assembly with a jack, & then undo the upper bolt (what size tool is needed?), but how does the lower one which is attached to the rear anti roll bar come off? .....is some sort of push fit?
    Robert
    Quote Originally Posted by Jekyll & Hyde View Post
    Just as an aside, also replace the nearside rear upper control arm
    On completion, perform a full four wheel alignment check
  1. rear drop links
    By beat275 in forum Suspension, Wheels & Brakes
    Last Post: 31st December 2012, 19:45
  2. Updated Saab drop links & front/rear powerflex arb bushes
    By pipamish in forum Suspension, Wheels & Brakes
    Last Post: 1st March 2012, 14:42
  3. Rear drop links ?
    By paul.sessions in forum Suspension, Wheels & Brakes
    Last Post: 27th February 2012, 12:08
  4. Rear Drop Links WTF????
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 20th February 2012, 17:51
  5. For Sale: Rear drop links
    By disco dan in forum Parts for sale
    Last Post: 17th December 2011, 14:50
vectra c rear drop links
changing vectra c rear drop links
how to change rear drop links on vectra c
how to replace vectra c rear anti roll drop links
how to fit vectra c rear anit roll bar link
fitting vectra c rear drop linksvectra c rear arb drop linkvectra c drop link replacementhttps:www.vectra-c.comforumshowthread.php136359-Replacement-of-Rear-Drop-Linksvectra c removing rear drop linksrear drop link vectrarear drop links vectra cvectra c drop links tools neededvectra c front drop linksreplace rear anti roll bar links vectra cdo other drop links fit my vectra chow to fit rear anti roll bar drop links on a vectradrop links vauxhall vectra cHow to fit rear drop links on a vectrachange rear drop links on a vectrahow are vectra c rear droplinks held on by a nut or push fitchanging rear drop link vectra cwhat does rear drop link on vectra c dovectra c rear droplink replacementvectra drop links
