Thread: help... hand brake cable removal?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Default help... hand brake cable removal?
    cant seem to find anything using the search guys.
    i need to change me caliper because its seized but a cant see how the cable swaps over onto the new caplier.
    if someone could give me a pointer urgently id be forever gratefull
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Mr Haynes say:
    'Disengage the inner cable from the caliper lever, then pull the outer cable grommet out of the caliper bracket.'
    No pics to help I'm afraid. I can only assume you release the handbrake, remove the caliper as if you are replacing pads, wind back the piston to remove any tension from the handbrake cable then the cable end should wiggle free allowing you to slip the cable through a gap and away from the caliper.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by Handyandy-UK View Post
    Mr Haynes say:
    cheers mate a thought the little plastic would pull out a just wasnt sure, was ****** tight, had to put some boiling water over it and pull out with molegrips
    but all done now ready for MOT retest in the morning
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    LOL, that caught me out as well mate, It was obvious it had to come out but I was sure it would snap before it moved, molegrips as said did the trick though.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    It's a pain. Felt like such an idiot sitting looking so long like how the he'll does this come out lol
    O well at least I no for future reference
  1. Hand Brake
    By crispy007 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2013, 18:05
  2. hand brake?
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2010, 21:59
  3. Hand brake lever removal?
    By 900ss in forum Suspension, Wheels & Brakes
    Last Post: 20th June 2008, 22:48
  4. hand brake
    By JATBOY in forum Suspension, Wheels & Brakes
    Last Post: 4th October 2006, 07:32
  5. hand brake
    By murf2484 in forum Suspension, Wheels & Brakes
    Last Post: 18th June 2006, 11:36
vectra c handbrake cable removal
vauxhall vectra handbrake cable replacementvectra c handbrake cabledisconnect vectra c handbrake cable from calliperhandbrake cable connectors vectravectra c handbrake cable replacementhow to release handbrake cable from calliper on VectraFitting vectra handbrake cablehttps:www.vectra-c.comforumshowthread.php136355-help-hand-brake-cable-removalhow to fit handbrake cable to rear caliper vaxhull vectravectra c caliper removalhow to remove hand brake cable from caliper on a vauxhall vectra c handbrake cable vectra signumvectra c z30dt handbrake cablehow to remove handbrake cable from caliperhow to replace vauxhall zafira handbrake cablevectra c handbrake cable slackenhow to remove handbrake cable from caliper vectra cvectra c handbrake cable releasefitting a vectra hand brake cableHandbrake cable removal vectra c 1.8how to strip a handbrake on a vectrahow do you change handbrake cables on vauxhall vectra 2007vectra c handbrake cable stuck in caliperremove handbrake cable vectra 1.9
