Thread: 2.2 direct
    Regular Member davidlewis24's Avatar
    bridgend / wales
    Default 2.2 direct
    hi everyone little help needed if possible, my car seams a little sluggish of late so my mate put his tech2 computer on it to find 1 fault code P1112 SWIRL FLAP PROBLEM he has now cleared the code but ive had no warning lights on the dash etc is this code anything to worry about ? thanks in advance
    vectra c
    2.2 direct
    2006
    Regular Member Knuckle's Avatar
    South
    When mine got serviced they checked for fault codes, that came up on mine i think too but mine runs fine. Might be an old one stored where it failed temporarily or something.
    If it aint broken, don't fix it is my motto with cars at the moment. Spent so much money fixing things that didnt matter, or werent the problem on previous cars wont make the same mistake again!
    If its sluggish though, perhaps there is something not quite right with yours....
    Full Member lizard's Avatar
    Oct 2006
    southampton
    14 Post(s)
    Quote Originally Posted by davidlewis24 View Post
    vectra c
    2.2 direct
    2006
    Mines a 55 plate with 22,000 on the clock and I've had 2 matey, in the process of fitting a catch tank to eradicated the problem but yes its a common fault. HTH...
    bridgend / wales
    Quote Originally Posted by lizard View Post
    will it make it sluggish ? also is it a expensive job mate
    Oct 2006
    southampton
    14 Post(s)
    I got it done under warrenty twice even though one was out of warrenty but argued with vauxhall that if it had done that mileage with a rep you would change it without question , clean the the throttle body matey that may help...
    bridgend / wales
    thanks mate ill give it a go
    Oct 2006
    southampton
    14 Post(s)
    There is a how to on here somewhere, I'll have a looksy...
    Oct 2006
    southampton
    14 Post(s)
    Here you go matey...
    bridgend / wales
    brill thanks mate
    bridgend / wales
    Quick update my car was tested on the computer again last night and the fault code P1112 was stored again after being wiped last week so there is a deffo problem. What do I do ? And is it a part I can buy from vauxhall ? Or is there a fix ? Thanks
  1. I think my 2.2 direct has too much oil in it....
    By Knuckle in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2011, 15:18
  2. vectra 2.2 direct/non direct
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2009, 00:05
  3. 2.2 Direct mpg normally this bad?
    By Marc C in forum Engine & Drivetrain
    Last Post: 9th August 2008, 12:46
  4. 2.2 Direct 16v
    By cdms811 in forum Petrol Engine related
    Last Post: 12th December 2007, 00:55
  5. 2.2 Direct
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 20:50
