Thread: GIDs/CIDs/TIDs/MIDs
    Regular Member Whisky's Avatar
    Mar 2011
    Kirkcaldy/Barrow-in-Furness
    confused GIDs/CIDs/TIDs/MIDs
    I'm going to upgrade my TID in my 05 1.8LS to a GID (or something along those lines!!).
    What else can I put in there? Would a Vectra B GID work? Widescreen Vectra C? Insignia Console?
    I also need to source a new Indicator stalk with the BC function and I think I need Tech 2 as well..........
    Suggestions welcome.
    Mar 2011
    Mar 2011
    again.........
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    What radio are you going to use it fore.. thats more dependant on what you can get in.. (and dosnt help bump every hour.. you wont get reply faster for that reason)
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    I am going to assume that an 05 Vectra will have a CD30, and therefore a full CAN triple info display.
    In which case, you would need a Full CAN display as follows
    BID (Board Info Display) if you just want Board computer functions
    GID (Graphic Info Display) if you want a less pixelly display, board computer functions and graphic symbols on your check control (if you have it enabled).
    You MUST get the display from a October 2004 (UK 54 plate) or later Vectra-C / Signum (fitted with CD30, CDC40, CD50 or CD70 and where fitted - scroller wheel controls)
    Astra-H / Zafira-B items would also fit, but are nigh on impossible to pair up to a Vectra-C head-unit.. due to code indexing etc..
    You could get a matching pair (Head unit and display) from a Meriva, Zafira-B, Astra-H, Corsa-D or a full CAN Vectra-C / Signum..
    But again programming requires the operator to select the donor vehicles details (model, year etc) to enable BC and Check control functions, or to change variance configuration functions...
    Mar 2011
    Sorry bout the "Bumping" kenp, will bear that in mind for future "bumps",lol. Its a half canbus, and its a CDR2005 head unit in mine.
    Engine : 2.2 Direct
    When its a CDR2005, theres a how2 for fitting a GID.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    If you have the CDR2005 radio / head-unit, then your car cannot be a 2005 vehicle, so all the comments that I have written above are totally irrelevant.
    You must only use displays from the 2002 to 2004 (Half CAN) Vectra-C or Signum - absolutely no other vehicles due to wiring differences.
    Definately not Vectra-B nor Omega-B
    Mar 2011
    That seems daft on Vx's part,that i can only replace it with one from an older model
    Engine : 2.2 Direct
    YOu can replace with newer.. but a lot more work..
  1. hello from west mids
    By mikey-sri in forum Introduce yourself.
    Last Post: 12th September 2012, 19:58
  2. hello from mids :)
    By le0nx3 in forum Introduce yourself.
    Last Post: 13th May 2012, 21:45
  3. pictures of gids
    By bigron1988 in forum Electrical & ICE (including SatNav)
    Last Post: 26th April 2010, 20:44
  4. Please explain about TIDs & GIDs ( and dont laugh)
    By MID LIFE CRISIS in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2010, 22:51
