Results 1 to 10 of 13
Thread: Notchy Gear Change...
    Bury St Edmunds
    Default Notchy Gear Change...
    I bought my 05 1.9CDTI 150Bhp Vectra about 3 weeks ago now. Love the car, but have one minor gripe, the gear change. The gear change feels so notchy when changing betwewen any gear. It almost feels as if the clutch wasn't fully engaged when changing gear.
    Is this normal? anyone else experienced this? or is this something specific to my car and therefore maybe a fault?
    Cheers,
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    gear linkage mate...had several problems with mine and same symptons...they also changed some cables in the gearbox..not a clue what they are but it has sorted it for now!!...hth...
    Bury St Edmunds
    Cheers for the advice Dwabo,
    So I guess I should take it to my dealer, ask them to take a look and hope that they know what the problem is and how to fix it?
    Regular Member Harry's Avatar
    Uxbridge, London
    yep definitely...take it to the dealer and ask them to have a look.
    on a cold morning the gear changing is worse, especially the low gears, but i think yours sounds a bit more serious than that.
    Regular Member threelitresofelitesig's Avatar
    Jul 2006
    Barnsley Area
    That's a problem with most of the manual gearboxes in the Sig I think, I have a 3 litre diesel and its a **** change.
    I would also advise getting it checked out, but it's most likely "how it is" as it's cable operated (so they tell me) - and its a pig to fettle.... Old Honda's were the same (oh how many times i took my prelude to the dealer for gearbox problems!)
    Regular Member Rodnoc's Avatar
    East Lothian
    Had the same probelm, so got it into the dealer.
    Mmmmmmmmm........... gear linkage naffed - warranty claim
    Needs adjustment now Sir...............£150
    Robbin B*****ds
    bedfordshire
    ive a 2.2 direct 04 estate, same thing notchy gearchange and some times locks me out of 2nd or in it? off to dealer on monday, the first time they said they cldnt find anything wrong?
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    Get the clutch bled, I had a notchy gear change mainly from 1st to 2nd when cold, took it to VX and they said thats normal,
    Took it to a local garage and paid £25 to have the clutch bled and it was fantastic,
    Its been A1 ever since,
    Regular Member denzo's Avatar
    Runcorn
    Vx told me that it was normal 2.5 years ago.
    I said that the linkage needs altering and they told me that as the car was just over 12 months old they would not alter for me - I would have to pay for an hours investigation and the labour to alter.
    I said .... so wwhat is this then knackers the gear box .... they said that they would then replace it under warranty.
    Following from that conversation I never went to a Vx dealer again and have had the car serviced by and indepedent guy since .... hardly notice the notchy gear change now, I change a little earlier
    Regular Member Eddie Dee's Avatar
    Feb 2007
    BELFAST
    I have the same problem and they are changing the flywheel under warranty!!
    I will have to keep the linkage in mind!
  1. notchy 2nd gear
    By eminemme42 in forum Engine & Drivetrain
    Last Post: 15th March 2012, 23:43
  2. Gear box oil changed and still notchy gears
    By dannycturbo in forum Engine & Drivetrain
    Last Post: 3rd September 2011, 19:26
  3. New Clutch and GB oil seal leak causing Notchy change
    By rowlybum1 in forum Engine & Drivetrain
    Last Post: 17th June 2011, 18:53
  4. Notchy 3rd Gear Automatic
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2009, 18:24
  5. vectra c 1.9 8v adjusting notchy gear linkage ???
    By lollypop in forum Engine & Drivetrain
    Last Post: 26th April 2009, 14:24
