Thread: vibration at idle
    Sep 2009
    norfolk
    Default vibration at idle
    Hi all,
    I'm getting a vibration, when the car is at idle, just for a few seconds, then it clears. It only happens when the car is warm.
    One time I got a engine light, when i got home i did the brake pedal, accelerator pedal test and I got an misfire on cylinder 6.
    I've got it booked in my local garage tomorrow, any idea what the cause maybe??
    Sig 3.0cdti 55 plate
    Where is this vibration in the vehicle?
    I had a very slight vibration that could be felt in both of the front seats
    Turned out it was the first signs of the failed DMF
    Sep 2009
    norfolk
    Yeah though the seats, pedals floor,
    Not a massive vibration, just noticeable.
    The DMF has already been done , under warranty about 20,000 miles back, the car has just clocked up 70,000.
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    dont say that i get this on drivers seat i hope it aint dmf
    West
    Quote Originally Posted by t1m View Post
    was the clutch replaced at the same time?
    As the car is under warranty get it in, NOW
    Vibrations like this are a nightmare to trace, but it sounds like the engine is the likely cause
    I didn't get a vibration anywhere else, just through the front seats
    Placed both hands between knees and it could be felt
    Others have reported as the DMF nears the end of its life it then starts to transmit a vibration through the pedals
    Mine just took the clutch with it instead
    What are the gear changes like?
    I reported, on numerous occasions, an inability to apply power on down changes, but they could never recreate it (and this went on for nearly two years)
    However, towards the end it did it all the time, I demonstrated it to the Service Manager and he booked it in, but the clutch went a few hours later!
    Sep 2009
    norfolk
    no the clutch was not done , so i could be that.
    Sep 2009
    norfolk
    The gear changes are fine, no problems there
    The last time the DMF went , I had a metallic sound when using the clutch.
    TBH , as its got a warranty wise warranty i hope it is the DMF as i can get the clutch done too.
    But with the misfire fault, I am wondering.
    When the DMF is replaced, the clutch MUST be replaced at the same time
    Even if you have to pay for the clutch, well worth it
  1. Vibration at idle... Injector?
    By Chunklamb in forum Engine & Drivetrain
    Last Post: 6th January 2013, 13:15
  2. vibration on idle
    By kamar in forum Engine & Drivetrain
    Last Post: 3rd April 2010, 13:38
  3. idle idle? haunted car lol!!
    By 1smokinace in forum Engine & Drivetrain
    Last Post: 27th May 2009, 21:28
  4. Replies: 4
    Last Post: 31st July 2008, 15:29
  5. FR 1443: Engine - Vibration at idle with switched on A\C system (Vec C)
    By Duncan in forum Heating, Ventilation & Air Conditioning (HVAC)
    Last Post: 25th June 2005, 16:48
