Thread: Z19DT OP-COM readout
    Nov 2010
    Denmark
    Default Z19DT OP-COM readout
    Hi.
    Hope someone here can help.
    I have the problem that my Z19DT judder/misfire, especially doing the regen. I therefore tried to record data with op-com, and there is something that seems a little strange, the value of the Rail Pressure Control Solenoid Valve, is zero in both % and current, does anyone know if this is a normal?
    Regards
    Nov 2010
    Denmark
    Some more readouts. Does anybody know if a Z19DT has a Rail Pressure Control Solenoid Valve, and if it has, where it is located?
    Calculated Pedal Position 0%
    Desired Engine Idle Speed 825 RPM
    Engine Speed 822 RPM
    Calculated Air Flow 43 kg/h
    Mass Air Flow Sensor 49 kg/h
    Charge Air Temperature 30 °C
    Charge Air Temperature 2.89 V
    Coolant Temperature 59 °C
    Coolant Temperature 2.21 V
    Fuel Temperature 17 °C
    Fuel Temperature 3.46 V
    Barometric Pressure 100 kPa
    Barometric Pressure 3.94 V
    Boost Pressure Command 120 kPa
    Boost Pressure 102 kPa
    Boost Pressure 1.64 V
    Pulse Ratio Boost Pressure Solenoid Valve 75%
    EGR Position Commanded (Exhaust Gas Recirculation) 100%
    EGR Pulse Ratio (Exhaust Gas Recirculation) 4%
    Desired Common Rail Fuel Pressure 27.87 MPa
    Common Rail Fuel Pressure 28.35 MPa
    Common Rail Fuel Pressure 1.11 V
    Rail Pressure Control Solenoid Valve PWM 0%
    Rail Pressure Control Solenoid Valve Current 0.00 a
    Fuel Metering Solenoid Valve PWM 36%
    Fuel Metering Solenoid Valve Current 1.40 %
    Differential Pressure Diesel Particulate Filter -2 kPa
    Differential Pressure Diesel Particulate Filter 0.43 V
    Diesel Particulate Filter Saturation 74%
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by Astra H View Post
    Hi.
    Regards
    Can we mention Op Com?
    Regular Member tramman's Avatar
    Selby, North Yorkshire
    As long as it is legit, which I would assume it is otherwise he wouldn't of asked the question after reading the T&C's. Op-Com is the european name of Vaux-Com, it is questionable when it is a UK member asking for help with Op-Com. Although I am sure a Mod will be along soon to raise any concerns.
    In relation to the question there is a ECU update available which cures the hesitation/juddering available from your dealer on the Z19DT engine, if this hasn't been carried out it may be worth a shot. But take note if they don't do it correctly, it can crash the ECU. Check out this thread
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    If it was a legit Opcom he would be on ilexa forums asking for support, some may ask why we delete and close so many threads regarding Opcom ? Reason is just that there have been loads of threads started asking for support or just general questions !
    Plus the fact they are copies and can do a lot of damage
    Sorry but thread closed
    Irmscher Insignia CDTI 130
  1. 1.8 maf readout...
    By Marvec in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 18:31
  2. diagnostic readout
    By gsi-robster in forum Electrical & ICE (including SatNav)
    Last Post: 26th April 2012, 18:06
  3. Anyone with a 'live readout tool' and 2.0T do me a favour?r?
    By ROCKATANSKY in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2011, 22:03
  4. Trip Computer live MPG readout.
    By pete63 in forum Electrical & ICE (including SatNav)
    Last Post: 17th April 2008, 21:36
  5. mpg readout
    By skippyroo in forum Vectra C / Signum Car Chat
    Last Post: 22nd December 2007, 20:03
opcom showing fuel temp -40
pulse ratio boost pressure solenoid valve
opcom fuel pressure
rail pressure control solenoid valve PWM 1 opcom
z19dt rail pressure control solenoid 0a
op-com common rail pressure
op-com values common rail pressure
