Thread: Rover 25 1.4i Idle Rev issues (trying to help a friend)
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Default Rover 25 1.4i Idle Rev issues (trying to help a friend)
    Hi folks,
    Im trying to help out a friend with his Rover 25 1.4i.
    Basically, when he comes to an idle state (i.e. lights, roundabout, etc), the rev's fluctuate between 500rpm to 2000rpm. Naturally when they go to about 500rpm the car usually fizzles out and stalls, then after a restart he can carry on until idle again and same problem.
    I have seen the problem but he says it also feels as though its misfirring!??!
    When the revs fluctuate, he says sometimes they just climb to 2000rpm and then if he gives it some throttle, they come back down and then start to hover again.
    Can anyone help? Quite urgent. Im going over to have a gander in about 40 minutes to any ideas and hints prior to that would be great as id like to go armed!
    Thanks.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    This forum's pretty good for Rover/MG problems http://forums.mg-rover.org/index.php
    Birmingham
    I have had a read, seems like it could be TB or even just a knackered cable.
    Regular Member V6 Nell's Avatar
    Staffordshire
    I had the same problem with my 25 1.4i.....sold it pronto and brought a Signum...problem solved.
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Not sure if the rover has similar components but my escort (many moons ago) used to do this.
    Turned out that the "idle control valve" was knackered. That sorted things for almost six months then it started doing it again. Figured it was the injection system that was up the spout so decided to scrap it.
    Hope you get it sorted
    chesire
    possibly a dodgy m.a.f sensor.. not to dear and some places will test the old one if you buy a new one off em
    West
    sounds like an idle control valve to me too, you can remove & clean them usually
    Birmingham
    Thanks for the info folks, I have passed all these details to chap in question. Now we have to try and find where the ICV is!!
    Year : 55
    Mileage : 92,000
    Think this is it:-
    Found from here:- http://forums.mg-rover.org/showthread.php?t=327460
    More here (LINK) including "Throttle position sensor reset" (not sure if this works on the 25 though)
    Google is your friend lol
    Good luck
  1. 3.2 , bad breathing , high idle , issues
    By biffbangpow in forum Engine & Drivetrain
    Last Post: 18th November 2012, 16:14
  2. Z20NET Rough Erratic Hesitant Idle Issues...... Help??
    By greenmonster in forum Engine & Drivetrain
    Last Post: 9th July 2012, 16:03
  3. Rover 45 loan car
    By the_wave_rider in forum General Chat
    Last Post: 17th February 2010, 20:17
  4. where`s the rover???
    By VEC-MAN in forum General Chat
    Last Post: 18th December 2008, 20:12
  5. Replies: 4
    Last Post: 31st July 2008, 15:29
