Thread: P0400 - EGR Flow Malfunction
    Apr 2011
    Workington, Cumbria
    Default P0400 - EGR Flow Malfunction
    Just read the fault code on my car and it came up with the above. It's a brand new valve that's been fitted. Is it just an old fault code that hasn't been erased? If not what could be the problem?
    Spanner light only stays on the dash when engine is cold for a couple mins which I found out to be a faulty glow plug, in process of changing.
    Any ideas lads?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    I think you've answered it, if you have a new EGR, then the EGR code is likely to be regarding the old one.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    With a new egr fitted i expect it to be a old fault code that should clear after 25 starts , then again it may be that the electric connection has not clicked home properly ,i once had an egr fault appear after cleaning my egr it turned out to be the electrical connection had been twisted the wrong way and was stretching the wire,s
    and still loving it
    Apr 2011
    Workington, Cumbria
    Right, thanks pal. I'll clear the code and see what happens.
    uk
    Did you get it fixed?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by jtg View Post
    Any luck with this.
  1. P0400 - Exhaust Gas Recirculation Flow Insufficient Detected
    By lencuff in forum Y & Z30DT Specific
    Last Post: 20th November 2012, 18:15
  2. Exhaust gas recirc flow prob P0400?
    By NPS in forum Engine & Drivetrain
    Last Post: 16th July 2011, 05:35
  3. P0400-F8 Exhaust Gas Recirculation Valve Feedback Signal Malfunction
    By Vectra Forever in forum Engine & Drivetrain
    Last Post: 30th June 2011, 15:19
  4. P0400-5B Exhaust Gas Recirculation Flow Excessive Detected
    By zafira in forum Diesel Engine related
    Last Post: 11th September 2010, 07:46
  5. Exhaust Gas Recirculation Flow Malfunction
    By H0885 in forum Troubleshooting
    Last Post: 20th January 2009, 20:20
vectra p0400 egr malfunction
vectra egr flow malfunction code
