Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: looking new car VXR
    Sep 2009
    Glasgow
    Default looking new car VXR
    Hi what problems are likely with the vxr, as my cdti has had nothing but problems, is it a simmilar story with the vxr
    Sep 2010
    bad news Nokia,.. can't fault my CDTI but just luck of the draw. Not heard many bad things about a VXR other than cost of the coil packs,.. but Spoons etc will give a full brief i'm sure
    Full Member Big Sig's Avatar
    Quote Originally Posted by nokiaman1978 View Post
    No they are much better. That's why there are not many threads about problems with the 2.8t lump as they are all basically the same.
    Hopefully an owner will be along with some better details but hopefully that's put your mind at ease a little.
    Regular Member PORKBALLS29's Avatar
    Epping
    Hiya, In the year i've owned my 2.8T I have had no engine worries at all. If you do the usual checks then they are a really good and reliable engine. The major things that appear to play up are MAF and coil packs as previously stated. All though obviously they are heavier on the fuel than a diesel I personally think they work out cheaper in the long run, when you look at all the problems the CDTI's seem to be riddle'd with.
    spoons
    Guest
    In most instances the 2.8 Turbo is very reliable. I've had no problems with mine at all in 3 years and 35,000 'super enjoyable' miles.
    I've had 'glitches' or gremlins. Weird ones like... one day my parking sensors didnt work.. but just for one day. one day my oil level light came on, but the level was fine... then the level light went away.... one day my cruise control stopped working... then started working again.
    So its very occasional weird stuff.
    Very few owners have had trouble with engine stuttering or juddering. This has been down to either a MAF sensor or Coil Packs needing replacement. These seem to be rare occassions though, but when it happens its annoying. Coil Packs can be bought for around £55 each. This has never happened to me though..
    Power steering groans when the fluid levels are running slightly low. Top it up and its fine.
    Get the engine remapped to Stage One. Its the best £350-£500 you can spend on this car. Loads more torque and a bit more BHP. Great fun but only fill it with 98-99 RON fuel on Stage One.
    Make sure the recalls have been done
    - Header Tank
    - Windscreen Wiper Motor
    - Handbrake Recall
    Oil Changes are dirt cheap, I can get the oil and oil filter for under £40 through trade club, so there is no excuse for not doing regular oil changes on this engine.
    Dont get one converted to LPG as its caused major reliability problems with other owners. Also, if you see a VXR you like, it would be well advised putting a description on here and VXRonline.co.uk in the Vectra VXR section to see if we have any history on it... before you buy it
    Errrmm... thats it really. Sweet as a nut
    spoons
    Guest
    Oh actually there is one problem....
    SPEED.....
    Apr 2011
    online
    Quote Originally Posted by spoons View Post
    SPEED.....
    But only if you get caught or can't afford the petrol
    Glasgow
    You if you dont mind paying more money to have a grin on your face then go for it. Had mine since january and love it to bits.
    Regular Member Vectralicker's Avatar
    Fife - unfortunately
    Be careful not to buy an Arden blue one thats an auto on 57 plate with low miles....... ahem
    Glasgow
    Quote Originally Posted by Vectralicker View Post
    Ill second that, what was the reg of that one?
