Results 1 to 10 of 11
Thread: Climate control
    Default Climate control
    Just got home from my night shift. As I got in the car I turned the dial to speed up the fan a little and it jumped from 2 to 7 with one click! It took me ages to get it slowed down. It was as thought the dial did not control the fan speed and it did what ever it fancied! 4 to 7, 7 to 1, 1 to 5 etc. Anyone else had this happen? It does not seem to matter how fast I turn the dial either
    Melbourne, Australia
    Sounds like a dodgy switch on the dial.
    Regular Member ope126's Avatar
    May 2006
    Brisbane, AUSTRALIA
    The same thing happend to me!
    The A/C Switch (Control Knob) was replaced under warranty though!!!
    All good now!
    I just told the dealer (Holden) what was happening and the replaced with no problems...
    Nicking Ya Dinner.
    With CC you get overriden by the sensors, read the handbook and you will probably find you need to set something else before you get manual control over it, my Omega used to just blow on full at the screen when it sensed the screen was misted up. hth.
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    My Meriva's climate control does the same if the direction is set to windscreen.
    Nicking Ya Dinner.
    There! sorted
    Its got to have a new part..... ecu something, aparently its common........
    I thought it should blow flat out when its in auto or on screen de-mist. Even if you set the direction to up it should still be controllable
    Quote Originally Posted by Astrase20
    I hope it's still under warranty... It's probably a 5 cent part that's failed but probably is only available as part of a $600 ECC control unit (translate that into your favourite currency...)
    You're right; the wheel should always override the automatic settings, even on demist.
    Quote Originally Posted by VauxVeteran
    You just need to turn the large fan speed dial and that automatically gives you manual overide - no matter what mode it's in - demist etc.
    As above, sounds like a dodgy dial.
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    My fan control dial did the same on my last car (jumps about at random and not in order when you turn the dial ... even decreasing the speed when turning it up and vice-versa in a random fashion) - they replaced the switch under warranty and it resolved the issue.
    HTH
    Dave
  1. another climate control
    By Даниил in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2011, 19:43
  2. Climate control and GID
    By Ben_ in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2011, 19:30
  3. climate control
    By stu_c in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2010, 18:27
  4. Climate control Help
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2009, 00:23
  5. Climate Control
    By liphook in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2008, 04:10
