Thread: wet mats
    Mar 2011
    hartlepool
    confused wet mats
    had my signum 2.2dti a few months now, and the drivers side carpet still soaking wet i done the scuttle drain clean which was full of water. so i'm now thinking could it be something else ie could water be leaking into the car via the windscreen its starting to do me head in
    Regular Member chrisknights's Avatar
    Feb 2011
    brighton
    your going to have to take the seat out and lift up carpets and put some one in your footwell and do a water test in different areas to try and pin point where its coming from
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    I hear its something to do with your pollen filter. make sure is isnt blocked. take it out and check all the duckts.
    I'm sure someone will clarify this.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Yea, that will be a blocked drain hole in the front scuttle panel. Lift the bonnet then lift the plastic inspection flap and you will see the pollen filter, just in front of that is the large drain hole and it will be full of old leaves. Push it through with your finger and your also best to replace the pollen filter. HTH
    Mar 2011
    hartlepool
    i done the scuttle drain thingy and all was well, had it in for a service tonight my mate a diesel fitter had a look and he reckons the windscreen needs taking out and refitting, on inspection the drivers side of the windscreen was a tadge loose. makes sense as only the drivers side footwell is damp.
    Vehicle : SRi
    Mileage : 137000
    Wow, never seen that before. There is another drain hole on the drivers side. If the windscreen is sealed then that being blocked alone shouldn't cause any problems, but if the screen isn't sealed then....... For a quick cheap fix try and get your hand in and clear that one as well but on modern cars the screen gives strength to the car so in time that will need looking at as well.
    Mar 2011
    hartlepool
    yeah cleaned both drain holes weeks ago but the carpet still wet, thats where i had my doubts about windcreen. gonna give auto glass a call see if i can get it took out and put back in properly. hope to get it free off the insurance
    Mar 2011
    hartlepool
    Quote Originally Posted by fozz View Post
    well it was a faulty fitted windscreen letting water in has now got new windscreen in all is well, no more wet mats
  1. Mats
    By barachello in forum Styling
    Last Post: 21st May 2011, 19:27
  2. Car Mats
    By M65 in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2011, 18:28
  3. Car mats
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2009, 10:59
  4. Which mats do you have?
    By fandango in forum Styling
    Last Post: 13th March 2009, 19:24
  5. VXR Mats
    By Caterman in forum Parts for sale
    Last Post: 14th May 2007, 16:09
vauxhall vectra drain holes site:www.vectra-c.com
