Results 1 to 10 of 11
Thread: Protect aircon condenser?
    Regular Member se4's Avatar
    Aug 2010
    wales
    Default Protect aircon condenser?
    My aircon has never worked since i bought the car last year, now it's getting warm it's becoming an issue.
    So it's booked in tomorrow to have the system checked over, from what I've read on here chances are it's the condenser (obviously I'm just assuming right now)
    As the car does a lot of mileage (circa 30k p.a.) and mostly motorway it is likely that stones and other objects will hit the front of the car from time to time.
    My thinking is if I have to have the front bumper taken off to change the condenser, why not fit a fine mesh behind the lower bumper grill, black mesh obviously! Not for appearance but to help protect the condenser.
    Any ideas/suggestions or tips or anyone else tried something like this?
    Sep 2009
    Glasgow
    sure someone on here has done this
    slough
    i did mine too bumper off bought alliminium mesh from B&Q cut up and fitted behind bottom grill you dont even see it when bumper refitted.
    The condensor should be able to put with general driving, but all it takes is one minute stone to damage it permanently
    My front bumper was hit by a large piece of debris from a HGV about 4 years ago, which dislodged the lower grille pushing it into the condensor
    The condensor has a mark from this
    However, there is more damage from insects and stones!
    On my previous Vectra it was the actual pump itself that failed first
    Regular Member SRiAden's Avatar
    Jan 2010
    Glasgow
    Pretty sure it'll just need a gas recharge. Think it's probably freon or something, cos they use that in fridges. Quite expensive from what I gather, well about 40 odd quid. Give that a try first.
    The price of regassing hasn't changed much in 10 years, probably as more and more cars have become fitted with air conditioning in that time
    My previous Vectra B had this done under warranty (after argument) Initially they charged the system with dye-based gas and then used UV light to check for discharges, although they spent more time checking the condensor
    Two were found, on the pipes with restricted access, and these were fixed under warranty with new pipes
    The system was then regassed
    Sadly the air conditioning pump failed a few weeks later
    It was agreed they woud not charge me for the regassing, as I had just paid for it a few weeks earlier (their mistake, it was actually warranty)
    11 Post(s)
    Quote Originally Posted by SRiAden View Post
    Think it's probably freon or something, .
    It's proper name is R134a
    = tetrafluoroethane, or cf3-ch2f. It has a boiling point of -26.3oC and a freezing point of -101oC. Its a non flamable gas. It's colourless, and its odour is slightly ethereal.
    http://www.refrigerants.com/msds/r134a.pdf
    Regular Member Exclusive BV's Avatar
    West Midlands
    mine was fine last season but not now, even tried it a few times during winter. This will be my second recharge. Our zafira aircon still works perfectly after 5 years but the wife never uses it
    Now the downside
    Restricting the airflow to the condensor, is going to vastly reduce the airflow through the radiator
    Not an issue in the winter, but could be in the summer
    Aug 2010
    wales
    I'm talking about this sort of stuff
    http://www.halfords.com/webapp/wcs/s...egoryId_165675
    Wont affect airflow one bit but should help stop debris hitting the condenser and the holes are reasonably small, smaller than those in the lower grill at least
  1. Aircon problems - Not working, if anything air gets hotter turning on aircon???
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 10:13
  2. aircon condenser washer part number for 1.9 cdti 2006
    By voxvectra7 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th September 2011, 16:26
  3. Aircon condenser
    By Dougb in forum Engine & Drivetrain
    Last Post: 12th May 2010, 17:55
  4. Change aircon to auto-aircon?
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 22:12
vectra c protect condenser mesh
vectra c mesh grill
mesh to protect aircon condenser
