Thread: Air Con issue / advice
    Regular Member gaz4d's Avatar
    Glasgow
    Default Air Con issue / advice
    hi everyone.
    I've a few questions regarding my Air Con.
    I've just noticed that it no longer seems to blow out cold air.
    I initially thought that it might need recharging.
    However, i've since realised that there now doesn't appear to be any difference in the engine noise/revs that there used to be when it was initially switched on. ????
    Any advice or suggestions would be greatly appreciated.
    i know Kwik-fit do the AC recharging, but i'd rather take it elsewhere before i let loose the K-F monkeys on it.
    So, if anyone could also recommend someone in the Glasgow / Hamilton area, that would also be greatly appreciated.
    Quote Originally Posted by gaz4d View Post
    They use a plug & play machine, which a monkey can quite easily manage to use.
    Mar 2011
    midlands
    Engine revs not dropping because low pressure switch not allowing compressor to cut in, i.e not enough gas. Like Big Dave says all these machines are similar and very easy to use. We have one at out garage. They simply recover gas, vacuum system and test, then charge with correct amount of gas
    Glasgow
    So, just to clarify.......
    I won't hear a dip or change in the engine noise because there is very little or no gas in the system.
    Hopefully it just needs a recharge and fill up then.
    Does anyone know if there are any garages in Glasgow (or surrounding areas) that'll do it for less than the £50 average ?
    Mar 2011
    midlands
    That's right m8. it isn't always that simple though. Regassing is always the first thing to be done afterwhich if air con still does not work other components need to be checked. This is where it can get tricky (and expensive)
  1. DPF Blocking Issue - Advice required
    By bothyboy in forum Engine & Drivetrain
    Last Post: 22nd September 2011, 15:17
  2. Newbe after advice, lots of advice!
    By rb199 in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 19:08
  3. DAB issue
    By qsdjdan in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2010, 01:12
  4. key fob issue
    By doghead632 in forum Bodywork & Interior
    Last Post: 25th August 2009, 10:22
  5. Another DPF Issue
    By mushy2007 in forum Engine & Drivetrain
    Last Post: 22nd December 2007, 11:26
