Thread: engine smoking
    exeter
    Default engine smoking
    i got a 2.0 dti sxi . i just want to find out how much oil should it burn and when the turbo kicks in i get a cloud of black smoke can any tell me is this normal? . i have been told it is?? but i cant see how
    West
    firstly a litre of oil usage in 1k miles is acceptable according to VX...
    as for the cloud of soot, it all depends how much... my old dti didn't smoke too much when booting it apart from when the boost pipe split
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    the black smoke you see in your rear view mirror is the particulates from the burnt diesel, commonly referred to as soot. totally normal, although i wouldnt expect it to be too thick a cloud. itll mostly happen after youve been cruising & then drop it down a cog & accelerate, at least thats when it happened with a previous diesel car i owned.
    the colour smoke you need to be worried about with regards to oil is the blue variety, a sure sign youre burning oil, either due to valve guide oil seals going or piston rings gone, but thatll usually be coupled with lack of compression in 1 or more cylinders, which you should get checked before you start taking stuff apart.
    i stand to be corrected on the above.
    exeter
    thanks for the advice . its does only happen when i boot it . because i got the wife to put her foot down while i looked from behide and thats when i noticed it . it starts with a clear exaust and when reved up a quick cloud of black smoke comes out.
  1. Smoking engine after rebuild
    By G4GAV in forum Engine & Drivetrain
    Last Post: 24th June 2012, 23:25
  2. Smoking engine? 1.9cdti
    By mr-s in forum Vectra C / Signum Troubleshooting
    Last Post: 18th April 2012, 10:05
  3. please help - need some advice on smoking from engine!!!
    By shelleps in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 18:36
  4. Signum engine judder and smoking!
    By arkhan78 in forum Engine & Drivetrain
    Last Post: 20th February 2010, 17:09
  5. Smoking Engine
    By george in forum Engine & Drivetrain
    Last Post: 3rd September 2007, 12:47
engine smoking
