Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Mirrors fell off - another Common Fault
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Default Mirrors fell off - another Common Fault
    Obviously another common fault with the Vectra - after fixing the handbrake system (it released itself on my drive and rolled into the garage door, smashing it to pieces), the rear suspension arms, both front springs, the battery and alternator, the thermostat, front suspension droplinks, arb bushes and numerous other common Vectra faults - the f****** passenger mirror falls out and smashes, replace that, only to find that the drivers side is also hanging on by a thread. What next?
    West
    depends what engine you have
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    as youve got a diesel itll probably be swirl bar, dual mass flywheel, EGR valve, split air pipes, the list seems to go on & on unfortunately.
    petrols on the other hand dont seem to suffer to the same degree, from what ive been reading on here.
    im curious, did you fix the handbrake yourself, or did you get the dealers to do it with the handbrake recall?
    Mar 2011
    hartlepool
    Quote Originally Posted by kentish_bloke View Post
    ermmmm does this apply to the signums? as i dont trust my handbrake
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Yes one of the rear calipers was not working properly_ they were aftermarket ones so I replaced them with GM ones and not had a problem since. It wasn't the usual handbrake lever problem that was subject of the modification, although this has been done.
    Catterick, North Yorkshire
    Exactly same happened to me aswell, 2 weeks ago passenger mirror fell off, although i put this down to it having a crack in it for the last 4 years until on thursday while driving i noticed drivers mirror vibrating like mad, just a tiny bit left holding it onto backing at top so popped it off, cleaned glass and backing up with a bit of nail varnish remover and applied copious amounts of superglue.
    Was yours the same as mine where all of the sticky stuff is still firmly attached to the actual mirror mounting plastic but has all come away from the glass!!
    11 Post(s)
    Quote Originally Posted by fozz View Post
    Yes.
    http://www.dft.gov.uk/vosa/apps/reca...eText=Blank&tx=
    btw, you should never rely solely on the handbrake to stop your tin box from running away. Its states in the highway code and all the Vauxhall handbooks to also leave the car in gear when parked up.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Yes.
    Thanks for that Dave - I'll have to read up on my Highway Code - although my 1965 copy doesn't mention anything about putting it in gear! Good job Vauxhall sent me that little sticker to remind me!
    West
    I thought it was common sense/practice to leave any motor in gear whilst parked up... maybe it was just how i was taught
    11 Post(s)
    On hills you should also turn your front wheels into the kerb as well (if facing downhill) or away from the kerb (if facing uphill)
    http://www.direct.gov.uk/en/TravelAn...code/DG_069860 (rule 252)
  1. Common Fault
    By Madmarky01 in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2012, 00:13
  2. common fault. so I thought
    By mattyj33 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th December 2011, 22:25
  3. Help Please, 2.2 DTi Common Fault?
    By chrisschild in forum Engine & Drivetrain
    Last Post: 8th December 2010, 11:05
  4. Mirrors suddenly fell off
    By Signumandneil in forum Bodywork & Interior
    Last Post: 15th May 2010, 10:28
  5. is this a common fault
    By don paul in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2009, 11:21
