Thread: Aux belt tensioner bolt...
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Default Aux belt tensioner bolt...
    ... Half of which is still inside the engine block.
    Is this going to be a realatively easy fix? It's just let go on the M6 Toll so got trailered the 90 miles home by the RAC.
    Engine is a 2.2 DTi.
    Thanks.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    How much is sticking out?
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    None, it's gone right on the block. It needs to be drillied out I think, if that's possible.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    I you can see and of it you may be able to tap it round with a chisel. Is it the top one or the bottom?
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    It's the bottom one, access through the wheel arch. I'll have a better look at it tomorrow. Wasn't a lot to see by torch light.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Not so bad then, the top one would have been an absolute disaster as access is very limited
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Yeah could be worse. Glad I heard it when I did. Had stopped in the M6 Toll services so the mother could do a loo break, left it ticking over and heard this clunk and a weird noise. Switched off, opened the bonnet, started up and noticed the belt not moving. Glad it went then not on the motorway.
    Regular Member eaglepva's Avatar
    Up North
    This happend to mine a couple of weeks back. they need to drop the engine a little to get to snapped bolt then drill it out. Cost me £120 to get it drilled and put back together.
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by eaglepva View Post
    Seems to be a common problem (not another one!) on this engine - just had same on a relatives car - I drilled a smaller hole into the broken end of the bolt and used an easy out/ screw extractor to get the broken end of the bolt out. The bolt was easy to drill, probably made from soft mild steel which is why it snapped in the first place.
  1. Snapped tensioner bolt, help :(
    By danny2009 in forum Engine & Drivetrain
    Last Post: 29th April 2013, 17:14
  2. fan belt tensioner
    By jodiexii in forum Y & Z30DT Specific
    Last Post: 15th December 2012, 11:50
  3. Aux belt tensioner
    By jamesr in forum Engine & Drivetrain
    Last Post: 15th December 2008, 20:56
where can i buy auxiliary belt tensioner bolt dor a vauxhall vectra
vauxhall signum 2.2 dti alternator belt tensioner bolt
