Results 1 to 10 of 14
Thread: The problem has returned!!!!!!
    Regular Member collyb's Avatar
    Mar 2011
    ireland
    Default The problem has returned!!!!!!
    im in dire straights here men,,,,,,, done me third injector mod 3 days ago,,,had 3 days of perfect motoring and then today,,,,limp mode and spanner light around 12 times today,,,,and a code p1125 on my diagnostic scanner,,,,,i know this is throttle body related,,,,ive already taken off my tb last week and cleaned it and re soldered the joints on the circut board of the tb acuator,,,,,but im still getting the code p1125 and limp mode and spanner light,,,but it only seems to happen every 2 or 3 days,,,then 2 or 3 days of grand driving,,,then back again,,,,,,,anybody know whats going on ???????????
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    First of all have the car idling, and feel the plug under the throttle body, dry pressing on the plug a bit (not harsh though), if the engine changes note then you know there is something in the TB that is not correct.
    Gazza4
    north east
    post up a pic of your injectors
    Mar 2011
    ireland
    my camera is broken roswell,,,,why u wana pic of them ??????????
    Mar 2011
    ireland
    im gona give that A go in the morn gaz.....my head is fried
    north east
    I have a theory one of your leak off pipes is leaking or one of the crush washes have given up.
    easy to tell, wetnes around the injectors = leak off pipe.
    Burnt carbon / black area around injector = crush washer
    Mar 2011
    ireland
    ya it is mate,,,number 3 injector is covered in tar like stuff around the bottom of it,,,but what does this have to do with code p1125????
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by collyb View Post
    P1125 may not be throwing the car into limp mode. Usually P1125 at worst causes the ECU to treat the engine like the throttle control circuit has went open circuit, and leaves the engine sitting at 1,500rpm with the spanner light.
    Gazza4
    Mar 2011
    ireland
    so is it possible gaz that the p1125 im getting is just a stored code and the leaking injector washer is causing the limp mode??
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Possibly, thought the tar stuff you described a few weeks back was on the plug.
    Is the injector wet wuith diesel?
    Gazza4
  1. HID returned !
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2011, 19:25
  2. Hunting problem returned
    By manimal in forum Engine & Drivetrain
    Last Post: 4th November 2010, 19:48
  3. Hello to all - I have returned!
    By chrisschild in forum Introduce yourself.
    Last Post: 9th July 2010, 17:22
  4. Hi - I've returned!
    By Terry Tibbs in forum Introduce yourself.
    Last Post: 30th January 2009, 11:02
  5. i have returned!
    By pogo in forum General Chat
    Last Post: 2nd December 2006, 10:50
