Results 1 to 10 of 19
Thread: Air con quick question.
    Sep 2010
    north east uk
    Default Air con quick question.
    Noticed that since the warmer weather my air con seems to have no effect on making the air any colder when turned on. I can hear the engine note change when i turn it on, but not getting any colder.
    Put it on diagnostics today & when i put the air con switch on, the field marked "AC information switch" (Air conditioning) becomes active. But the field marked "AC Relay (Air conditioning) remains inactive. As shown in pic....
    Any ideas anyone?
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Good guess it's the old favourite .... low gas pressure (propapbly a leak) causes low pressure switch to kick in, thus isolating the AC to protect it from further damage.
    You can :
    Get it looked at by a professional.
    Get a look at the most common culprit - the condenser - and more than likely replace before having the system regassed.
    Take it Kwik-Fit and have them bung it on their machine for a very basic check and regas.
    Personally, I'd be changing the condenser if it's the original - especially after the cold winter - all that road salt sprayed onto it - great for corrosion and then off to my local Kwik-Fit for a regas.
    (Remember all Kwik-Fits are franchises so the standards of workmanship will be different at each).
    Barrow In Furness, Cumbria
    As above. The compressor doesn't seem to be kicking in so would guess low on gas either due to a leak or because it hasn't been run for a while.
    OpCom is just identifying that the switch is on but the compressor isn't.
    Quote Originally Posted by mick.n View Post
    Any ideas anyone?
    Little use = seals dry out and the refrigerant leaks out.
    AC needs to be regularly used, even in winter. Also makes for a great demister, and can also be used in conjunction with the heater - which is how the more expensive climate control systems work.
    Regular Member DarylAAS's Avatar
    South Shields
    look through your lower grill straight infront of you you will see the condensor.. look at the lower part of it.. if its hanging off or looks damp the your condensors ******ed
    Sep 2010
    north east uk
    Thank you for the replies gentlemen. I had a look at the condenser & it looked to be in good nick. The son works in the trade & can get it regassed FOC, so i will try that first.
    Only had the car since october last year & being mindfull of the seals, i made a point of running the aircon throughout the winter.
    But will try regass first & see what happens.
    Sep 2010
    north east uk
    Well, it lasted a year. Under pressure & not coming in again.
    No sign of condenser leakage though. Will try another regass.
    May 2012
    NW UK
    Nice one! Updating after a year
    I wouldn't think it would need re-gassing every year, but if your son can get it done FOC then why not?
    Sep 2010
    Why does the Vectra need to be run in winter to lube the seals and other cars don't?! ...
    All three of my Vec C cars have this problem and my partners (my old one) has had AC issues since 2010 which the dealer still hasn't resolved. I've got VX involved now as the dealer seemed to be not interested in sorting it out (identified when under warranty)
    Quote Originally Posted by chewy71 View Post
    Such as?
    It's good practice to run the AC regularly on any car, building installation, or portable AC unit, etc.
  1. quick question
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2011, 21:39
  2. Quick Question - Need a Quick Answer if Possible
    By RobW in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2011, 23:55
  3. DAB Box quick question
    By qsdjdan in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2009, 01:25
  4. Quick Question
    By Perry in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2008, 22:14
  5. A quick question
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2007, 14:53
